Find a radiator shroud OR go electric fan? - JeepForum.com
post #1 of 8 Old 04-22-2013, 02:23 PM Thread Starter
JUNK726
Guest
1974 J-Series Truck
well fellas..making progress on getting the ol J10 tuned up and running..(1974 Jeep J10 w/amc 360)..i discovered the PO had pulled off the radiator shroud...so i spent all weekend in the Pick n Pulls AND J&W jeep boneyard..to no avail! EVERY wagoneer and j10 truck had them pulled n gone...ebay wants $200 for re-pop! BUT i am wondering what u guys think? I found like 3 Contour fans and have already done this swap in my 4.0 CJ7..i did do the Flex-a-lite controller box made it easier but like $200..ugh...so i know how to do the swap..no worries..just curious which route is better to go..(was hoping the shroud would be ez find and cheaper so i can spend cash on new tires..but..ya know how it goes!
thanks all for any input! i will post updates next weekend once i have new valley pan intake gasket in, edelbrock carb rebuilt, and new water pump/hoses, and Team rush style upgrade ALL done! or wishful thinkin..but ima try!
JUNK726 is offline
post #2 of 8 Old 04-22-2013, 05:27 PM
pleontks
1976 J-Series Truck
If you can't find the shroud for a reasonable price, do the elec fan. An electric fan with on/off switch would have saved me a couple in my j10 so far. Ice puddles are fun for me, but not Apricot.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 8 Old 04-22-2013, 06:00 PM
RockRollin
1990 FSJ Wagoneer
Is it heating up, I haven't had any temp issues due to my lack of shroud.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 8 Old 04-22-2013, 09:44 PM
super98lsc
I just installed a new 3.8 Taurus electric fan in the ls powered 63 Galaxie it pulls like 4000 cfm. I dropped it in wagon for a test fit it looks good. 80 bucks shipped! Its a two speed motor so can also use a two speed controller, have low run till it hits say 195 then fires up high speed. Always run high when AC on. Toss in toggle for of road use
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #5 of 8 Old 04-23-2013, 12:29 AM Thread Starter
JUNK726
Guest
1974 J-Series Truck
no overheating problems as of yet..i was just curious as i was surprised of the over 20 Wagoneers and j10's in boneyard not a one radiator shroud! Even on the ones with motors in them untouched...so maybe i am overthinking it..may be just fine without! thanks guys! i will see how she rolls..and then may have to go grab a contour fan if all else fails..i may be just fine way it is! thanks a million guys! i am SURE my next dumb question will soon follow as build progresses! i did see a SWEET stock radio in one of the j10's today! wow...took me back! i may have to see how much gold, or maybe a kidney they may want for it!
JUNK726 is offline
post #6 of 8 Old 04-23-2013, 03:36 AM Thread Starter
JUNK726
Guest
1974 J-Series Truck
and for the record...i cannot rant enough/agree with everyone who has ever done the valley pan intake gasket fiasco... WOW. what a giant PITA!! but i got it done..and now i will be crossing my fingers i didn't "over RTV" seal it!...fingers crossed she sealed up tight! ok..enuff..thanx guys!
JUNK726 is offline
post #7 of 8 Old 04-23-2013, 04:24 AM
RockRollin
1990 FSJ Wagoneer
The shrouds were not built too tough for sure. When I got my Wagon it had the top 2/3rds of the shroud, And while it was running I leaned on it (more like rested my hand) and it shredded. Fortunately it didn't get my hand (DUHHUH)
"I like fun" Edd
post #8 of 8 Old 04-23-2013, 12:37 PM
rabbott1
1985 J-Series Truck
This is gonna sound kinda funny, but it worked! I had the same problem with my J-10 gettin hot, no shroud. I got inventive and found some landscape edging, you know the black plastic stuff about 6-8 inches wide. Using tec screws (self tappers) I screwed one end into the radiator mounting bracket, looped it over the fan flush with the top of the radiator and screwed it to the other side bracket. Worked like a charm! no more overheat, and doesn't look half bad either.
rabbott1 is offline
