-   Full Size Jeep Forum (http://www.jeepforum.com/forum/f57/)
-   -   A few QT questions (http://www.jeepforum.com/forum/f57/few-qt-questions-1539606/)
jetsetter57 06-21-2013 05:44 PM
A few QT questions
First the park to reverse seems a kick in the pants every time....no matter how low I adjust the Idle. Second when I punch it at all straight or even around a corner easy the rear tires chirp from 1st to 2nd. I'll be the first to admit chirping 35's isn't all that awful but I'm sure it shouldn't be happening.
4:56 gears in the rear and driveshaft out of the front awaiting parts. D44's front and back.
Any knowledge would be great,
Thanks
One more thing. When would I ever be using the vacuum switch in the glove box? And the lever by the driver seat on the floor?
pleontks 06-21-2013 08:55 PM
park to reverse clunk is normal. Is either wear on output of tranny, or slack in q-trac chain.
Due you have a part-time kit, or is the tcase stock?
Is your axle stock? Any locker or posi or anything?
Vacuum switch locks front and rear axles together. Basically, your jeep's AWD, and the switch puts it in 4WD. I only use mine when I'm stuck. NEVER have it on while on pavement.
Lever is hi/lo. Down is hi, middle is neutral, up is lo. When down (hi), the lever is usually pretty darn close to the floor. I have to smack mine in with my palm, because there's no room for my fingers.
I've heard a lot not to drive with the front driveshaft out. I'm sure someone else will chime in with more knowledge on that.
jetsetter57 06-21-2013 09:37 PM
All I know is that they're d44 front and rear (6lug). There are hubs on the front wheel centers and none on the back(like 6in protrusion front, rear flush). What else can I do to tell exactly what axle/yr the front and back are? How would I tell if tcase is stock?
I was told the rear diff is a locked diff...all time power to both rears.
super98lsc 06-24-2013 01:54 PM
if the rear is locked as in a full/mini spool then you will squeal pretty easily on turns and it will be tough driving it on the street. I removed the spool from my 63 Galaxie project and installed a clutch type traction lock in the 9" ford rear for that reason. Is the trans shifting normally or slamming between gears? Might be time to check and perform a band adjustment on it.
jetsetter57 06-24-2013 06:11 PM
It slams into reverse 90% of the time and if I don't let up on the gas shifting into 2nd it'll slam. It's a th400.
lucdog 06-24-2013 07:46 PM
Sounds like a shift kit was installed in the transmission. I'm also thinking the ring and pinion may have excessive backlash. Or like mentioned above, slack in the chain, or a combo of both.
On the rear being locked, the only way to know for sure is to pull the differential cover and have a look. It wouldn't hurt to replace the fluid anyway. I assume with the front driveshaft removed you are either driving it in "E" drive. Or not currently driving at all.
On the front axle, are there lockouts, or just a round chrome cover a out 3" in diameter?
Bill
jetsetter57 06-24-2013 08:03 PM
Round chrome cover 3" on the front hubs. I need to pull both back and front diff covers. I'll take pics. The rear is 4:56(allegedly) so I need to confirm before I take it in because if the front aren't at least a 3:56 I need a carrier offset adjustment or something like that.
As far as driving it, it's doing great with power just to the rears. Went off roading and it performed beautifully. Obviously I couldn't follow the little jeeps over the boulders but power was great.
Is it better to mod the vacuum switch (AWD to 4WD) than the glove box? Manual setup best? Heard the switch isn't all that reliable.
lucdog 06-24-2013 09:24 PM
I'm use Using the stock set up. But I also have lockouts and run "E" drive most all the time. This is a 90% trail Jeep.
I've not heard of switch/valve problems over in the CJ section. If I had problems with either I'd go with a cable,
Bill
The time now is 04:45 AM.
