Factory alloy wheels on J10 - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Factory alloy wheels on J10
Save 5% Off Of All Orders In August - Promo CodeJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinTJ & LJ Safari Cab Hardtops - $450 off expire 8/31/201
Unread 05-11-2015, 09:23 AM   #1
Cmcclaflin31
1982 J-Series Truck
Has anybody had problems with the factory alloy wheels on a j10? I had steel wheels and just put the alloy wheels on but they seems extremely close to touching the brake caliper... Within 1/4" I'm hoping this is normal. Please let me know if anyone else has this problem
Cmcclaflin31 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 11:24 AM   #2
lindel
As far as I know, the factory wheels for a J10 would be steel wagon wheels. Alloy wheels were used on the Grand Wagoneers, but not on the Cherokees or J-trucks. Can you post a pic of the wheels in question?
Lindel
His: 1999 TJ Sport
Hers: 1987 Grand Wagoneer
lindel is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 12:56 PM   #3
CSP
That 1/4 of clearance is all you need. It's not like either the wheel or caliper is going to move in a way that they ever get any closer.
J10 brakes are the same as Waggies and Cherokees, so clearance would have been the same with either of them.
CSP is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 02:21 PM   #4
Cmcclaflin31
1982 J-Series Truck
On the passenger side its almost scraping the wheel...
Now I'm not completely sure these are factory rims but that's what I've been told. So any help would be great!
Unread 05-12-2015, 05:40 AM   #5
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
I'm only aware of four different stock aluminum wheels, the slots from the 70s, the ten hole from the late 70s, the turbines from 88-91, and the 12 spoke from 80-87. Those look like none of them. There may have been other types (not a historian) but I've never seen that wheel on a FSJ.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline   Reply With Quote Quick reply to this message
Unread 05-12-2015, 09:13 AM   #6
Cmcclaflin31
1982 J-Series Truck
I know the early XJs had those 10 spoke alloys but they were 5 lug obviously. And they were slightly different
Unread 05-12-2015, 11:48 AM   #7
CSP
I've never seen that wheel on a FSJ either.
Unread 05-12-2015, 03:56 PM   #8
Cmcclaflin31
1982 J-Series Truck
Like I said, I was told they were factory but am not sure. I guess they aren't. Well thanks for letting me know!
Unread 05-13-2015, 12:17 AM   #9
j10jim
1980 J-Series Truck
No they are not factory rims.
j10jim is offline   Reply With Quote Quick reply to this message
Unread 05-13-2015, 11:03 AM   #10
lindel
They might have been factory on a Chevy/GMC, but never on a FSJ. All the FSJ alloy rims I've ever seen are a 15x7. That looks very close to one of the smaller Cherokee or maybe Comanche wheels, but those would be a 5 lug rim.
Lindel
His: 1999 TJ Sport
Unread 05-13-2015, 12:48 PM   #11
Cmcclaflin31
1982 J-Series Truck
It's actually a 15x7.5" which I found quite odd
Unread 05-15-2015, 06:57 PM   #12
lindel
Hmmm...it's also possible they were a factory wheel for a Toyota, Nissan/Datsun or something along those lines.
Lindel
His: 1999 TJ Sport
Unread 05-15-2015, 07:22 PM   #13
Cmcclaflin31
1982 J-Series Truck
You know, it's funny you say that because I just remembered the lug nut(only had 2) that came from it was a 12mm x 1.50 so you might be on to something! The guy at Endangered Species Jeep ordered those exact ones for me and questioned exactly what it was I was building. Obviously I had to order the lug nuts with 7/16 thread but still it was interesting...
