extremly hot engine question and high oil pressure when driving? - JeepForum.com
post #1 of 4 Old 07-30-2012, 08:40 AM Thread Starter
mpatch
1989 FSJ Wagoneer
I drove my 89 wagoneer about 20 miles one way and got back to the house and notice the engine was extremly hot. I could barely touch the oil dip stick. Not that familier with engines. Is that normal or should I be concerned. My oil pressure also rides real high until I come to a stop and then it drops down. Does this happen in other jeeps? In addition when I first checked the oil it looked after driving it and then it seemed to go back up after a few minutes. Again normal or not? Any ideas?
Matt:
mpatch is offline
post #2 of 4 Old 07-30-2012, 10:14 AM
pleontks
1976 J-Series Truck
everything's normal.
engines get crazt hot ridiculously fast. has to do with the fire inside of it.
oil pump is ran off the dist which is ran off the cam. as rpm icreases, so does the pumping of the oil pump.
always check your oil after it's cooled. the oil pump pumps the oil from the bottom to the top, where it drains down through the engine back to the pan. when you shut off the truck, the oil has to drain back down, still.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 4 Old 07-30-2012, 12:32 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
okay, how about some actual numbers?
"hot" and "high" are both VERY subjective terms.
What does your temp guage say, and what does your oil pressure gauge say?
40-60 PSI is good for oil pressure when running at a normal speed, it'll be closer to 50+ on the highway, at least it SHOULD be. What you should be worried about is how low it goes. My pressure is about 50PSI on the highway, but when i come to a stop it drops to about 13psi, which is pretty much within spec for an old AMC motor. you WANT higher oil pressure (not 'too' high, but most systems have a pressure relief valve to keep it from going over 60)
Temps, thats another thing. Are you saying its hot only because you cant touch the oil dipstick? Thats not a very good method of judging engine temps. if my truck is running at a cool, comfortable 190 degrees, I still cant grab the dipstick, because guess what, 190 is hot to the touch. i cant touch the radiator either.....
your engine should operate between say 180-220 degrees. A stock thermostat in a wag is going to be something like 193*, so it'll always run warmer than that. mine used to cruise on the highway at about 210. i've had it up to 230 which is overheating range, but it still kept on trucking just fine.
we need actual numbers to know if its 'too much' or 'too hot'
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #4 of 4 Old 07-31-2012, 08:20 AM Thread Starter
mpatch
1989 FSJ Wagoneer
Thanks, Let me take a look later and I will get back to you.
mpatch is offline
89 Grand wagoneer engine swap question gimme_fuel Full Size Jeep Forum 13 01-10-2009 12:57 AM
I6 engine question Mc83J10 Full Size Jeep Forum 0 07-06-2008 09:19 AM
oil pressure question dlee Full Size Jeep Forum 3 10-29-2004 07:19 PM
86 GWag engine question lzjarrett Full Size Jeep Forum 1 06-12-2004 05:57 AM
Engine pressure neo18 Full Size Jeep Forum 1 11-03-2002 05:29 PM
