Exhaust Headers - JeepForum.com
post #1 of 16 Old 12-14-2012, 07:19 AM Thread Starter
ejeter45
1987 FSJ Wagoneer
Exhaust Headers
All,
I am currently building a 87 Grand Wagoneer..Allready had engine built (approx 360 HP)
I am looking for headers....or some header advice
I dont mind spending money for a good part
the only ones that Summit will say fits for sure is the Dougs headers $850
and that is just toooo much......
I am looking for ceramic coated to help keep the heat down
Does naybody know of any headers that fit?
there are several sets but not for the 87 and summit will not confirm they fit
I spoke with Headman yesterday and they said 99256 or 99250 But they are not listed as fitting (not sure the guy on the phone knew what he was talking about he wasnt 100% )
And it looks like there was possibly a frame change before 87
What headers do you have and do they fit ?
Any ideas are very appreciated ?
Thanks
Eric
83 CJ-7
87 Grand Wagoneer
ejeter45 is offline
post #2 of 16 Old 12-14-2012, 09:36 AM
pleontks
1976 J-Series Truck
everyone i've known with headers on their FSJ sacrificed their front driveshaft to clear the exhaust.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 16 Old 12-14-2012, 10:36 AM
realmccoy
I ran headman headers on mine for years ,
Didnt have modify anything to run them
1988 Grand Waggoneer (20 years of service and still running strong)
realmccoy is offline
post #4 of 16 Old 12-14-2012, 03:11 PM
paintballtruck
1979 J-Series Truck
ive got headman headers on my 79 j 10 and they fit no problem
paintballtruck is offline
post #5 of 16 Old 12-14-2012, 03:30 PM
RockRollin
1990 FSJ Wagoneer
Thorley headers http://www.bjsoffroad.com/prod-650.htm . Expensive but from everything I've read well worth it
RockRollin is offline
post #6 of 16 Old 12-14-2012, 04:53 PM
BJ's Off-Road
1979 FSJ Cherokee
Thanks for the link, these are great headers and well worth it.
You will not have to sacrifice your driveshaft to run them. They tuck up real nice especially in the 1980-1991 FSJ's, a couple years ago we had them redesign the ypipe for these years.
BJ's Off-Road is offline
post #7 of 16 Old 12-19-2012, 09:57 AM
wmdeal
1973 J-Series Truck
I'll second the Doug Thorley headers. They do sound nice. I'll send you a PM about the set that I have.
wmdeal is offline
post #8 of 16 Old 03-09-2013, 06:12 PM
mkimball72
1986 FSJ Wagoneer
So which headman headers did you guys run? And they just bolted right up to both the heads and the y?
mkimball72 is offline
post #9 of 16 Old 03-09-2013, 06:53 PM
RockRollin
1990 FSJ Wagoneer
The only headers that still use the factory y-pipe were the Edelbrock, and they have been discontinued. IMO the use of the stock y-pipe negates the flow of any headers, the y-pipe is the bottle neck even in the stock system. You would be better off porting the first bend in the stock manifolds and open up after the y-pipe to a 2-1/2" exhaust.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
post #10 of 16 Old 03-09-2013, 09:40 PM
mkimball72
1986 FSJ Wagoneer
Appreciate it.
post #11 of 16 Old 03-14-2013, 03:55 PM
USAFfsj
1983 FSJ Cherokee
Hedman headers
I ran hedman headers on mine, true duals. I had to do custom bends to make it work but it did. sounds good and good power. I paid 350 or so for non ceramic, non issue other than the rust after awhile. Of course i live in PA, everything gets rusty no matter what.
USAFfsj is offline
post #12 of 16 Old 03-16-2013, 07:48 AM
mkimball72
1986 FSJ Wagoneer
I'm not looking for the slight performance gain u may see at street rpm's. I just want to ditch my stock exhaust and the emissions labyrinth under my hood and didn't want to run duals. Appreciate your input.
post #13 of 16 Old 03-16-2013, 10:33 AM
jeepdj5
1982 FSJ Cherokee
Use the manifold! Then u won't be burning plug wires
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #14 of 16 Old 03-16-2013, 01:53 PM
BJ's Off-Road
1979 FSJ Cherokee
Use the proper plug wires and good headers and this will never happen.
post #15 of 16 Old 03-16-2013, 10:47 PM
super98lsc
I'm goin thorleys from bjs.... For the across the board gain why not, bolts up clean etc.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
