Exhaust/carb combo - JeepForum.com
post #1 of 2 Old 03-17-2013, 08:38 AM Thread Starter
WOLFMAN75
1989 FSJ Wagoneer
Exhaust/carb combo
I have removed smog parts and want to install hedders with a manual choke simple carb. I assume cat needs to be removed since heat riser will be removed with drivers exhaust manifold. Currently have stock carb, what is the easiest solution? My concern with stock carb is choke?
WOLFMAN75 is offline
post #2 of 2 Old 03-17-2013, 09:59 AM
revelc
1985 FSJ Wagoneer
You don't have to remove the cat. With headers you might want to leave it to quiet it down a little and retain back pressure.
For the carb. Go to a parts store and get a universal choke cable. They are easy to set up.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
