Engine pressure - JeepForum.com
post #1 of 2 Old 11-03-2002, 04:09 PM Thread Starter
neo18
Engine pressure
I have an 88 jeep wagoneer. A few months ago i rebuilt it bored .30 over, with new cam pistons,what have you. it runs great, I'm having a problem with a large amount of pressre inside the vavle cover pushing oil throung the fill cap and, gromets on top. What could be causing this? is there something i may have missed?, what's a good fix for the problem?
neo18 is offline
post #2 of 2 Old 11-03-2002, 05:29 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Your PCV valve handles crankcase pressure. You might want to check to see if it is hooked up to manifold vacuum. You also need to check the valve to see if it is plugged. Hopefully this will fix your problem.
jeepdaddy2000 is offline
1990 GW oil pressure sending unit placement 90GrandWagoneer Full Size Jeep Forum 5 07-19-2013 11:20 AM
360 operating temps an oil pressure silvercert Full Size Jeep Forum 13 03-05-2010 06:33 PM
What fuel pressure rating? JOKER4INK Full Size Jeep Forum 5 10-30-2005 05:49 PM
oil pressure question dlee Full Size Jeep Forum 3 10-29-2004 07:19 PM
Oil Pressure Mysta_Killa Full Size Jeep Forum 0 08-12-2002 10:34 AM
