Electrical question - JeepForum.com
post #1 of 11 Old 03-16-2013, 08:03 PM Thread Starter
cookingguy
1979 FSJ Cherokee
Electrical question
So when driving at night time with my headlights on they pulse to the beat of my bass on my stereo. also so do the dash lights.
I have an 800 W amp hooked up to a 10inch box. my question is if put in a high output alternator in will that take care of my problem. I think I need a new alternator anyways because the volt meter on the gauge the needle is just above the 0
cookingguy is offline
post #2 of 11 Old 03-16-2013, 08:07 PM
JbmLaredo
All you need is a capacitor installed on your Hotwire to the amp it absorbs the sudden draw when the amp hits so no lights will dim. U can pick up a cheap one at ur local Walmart
JbmLaredo is offline
post #3 of 11 Old 03-16-2013, 09:20 PM Thread Starter
cookingguy
1979 FSJ Cherokee
cool thanks for the infor will be getting one tomorrow. Is it pretty easy to hook up? auto electrical is not my strong point.
post #4 of 11 Old 03-16-2013, 09:29 PM
RockRollin
1990 FSJ Wagoneer
Has your battery died? Is the guage bad? If just above zero I wouldn't think it would last long. Also is amp wired directly to battery with remote wired to HU, and what year rig are we de aling with?
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #5 of 11 Old 03-16-2013, 10:00 PM
JbmLaredo
Naw they are a piece of cake the instructions are in the box with the cap. As far as your volt gauge goes its not giving the correct voltage. There is no possible way to have just above zero and you were driving down the road with headlights on... Much less running subs lol I would take it to the nearest auto parts store and have them check alternator and load test the battery just to make sure they r in good shape
post #6 of 11 Old 03-16-2013, 11:43 PM
super98lsc
depending on year or not for an 800w amp I'd upgrade the alt to a cs144 amp. Amps = watt/volt so 800/12 = 66.67amps which is damned near the full output of an 87 or 94 amp factory alt.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #7 of 11 Old 03-16-2013, 11:46 PM
Siva283
It takes the voltage reg time to adjust output. You might want to look into a one farrad capacitor. It is hook up to your amp power wire. It keeps the electrical system from seeing those pulses from the base.
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #8 of 11 Old 03-17-2013, 09:31 AM
RockRollin
1990 FSJ Wagoneer
Now I have to check......thanks y'all...... I run a 1k amp, 200w amp, with no dim issues. I wonder what alt I have?
"I like fun" Edd
post #9 of 11 Old 03-17-2013, 09:31 AM Thread Starter
cookingguy
1979 FSJ Cherokee
so it is a 1979 cherokee. What should my voltage out be re reading.
post #10 of 11 Old 03-17-2013, 09:34 AM Thread Starter
cookingguy
1979 FSJ Cherokee
The battery has not died and the amp is wired to the battery and a remote wire to the HU and its a 1979 cherokee
post #11 of 11 Old 03-17-2013, 10:30 AM
RockRollin
1990 FSJ Wagoneer
13.8 min while running. If its not killing the battery, the cap is the answer, easy to install. I would be getting the guage fixed though.
"I like fun" Edd
