driver door window stuck - JeepForum.com
post #1 of 4 Old 09-25-2010, 01:00 PM Thread Starter
wagoneerpioneer
1987 FSJ Wagoneer
Hey everybody!
I have an '87 Grand Wagoneer and the other day my driver's side window got stuck down and now won't roll back up. The electric motor is running fine but it doesn't seem to be catching the window to push it back up. Any suggestions on what may be wrong, and more importantly how to fix it?
Thanks!
wagoneerpioneer is offline
post #2 of 4 Old 09-25-2010, 03:36 PM
ndm06
1989 FSJ Wagoneer
Sounds like your window flex track is broke. They are plastic and break from time to time. They cost under $30. You'll need to remove the door panel, remove the rail the track rides on and slide off the broken track. Apply some grease to the rail and the new track and install.
ndm06 is offline
post #3 of 4 Old 09-27-2010, 09:18 AM Thread Starter
wagoneerpioneer
1987 FSJ Wagoneer
THANKS!!! Found it, and I have the track on its way now.
post #4 of 4 Old 09-27-2010, 04:07 PM
CutterN55
I've gotten pretty good at the flex rack replacement. I just unbolt the bracket for the motor and the track from the door and angle the top back about 30-45* and stick the top end out a hole in the door and pull the old track off and lube up the new one and slide it on. run it down a little ways and push the window switch down to suck the track back a little so the top little piece is out of the way. put the bracket and track back in position and run the screws in a few turns and push the widow up and put the top little piece in the widow lifter and run the window up and tighten down the screws. I've got this down to under 30 minutes. I do it this way because screwing with the greasy 1/4" bolts that hold the motor on the track are a pain in the butt and I've got big sausage fingers.
Semper Fi!
86 CJ7 258/Np435/D300/Waggy D44's
CutterN55 is offline
door , power windows , repair , window
89 Wagoneer window is stuck open Neo_frog Full Size Jeep Forum 3 05-29-2010 08:40 AM
Rear Window Stuck Open markym Full Size Jeep Forum 18 02-01-2010 04:50 AM
Tailgate stuck closed Patriotic_Giant Full Size Jeep Forum 8 12-13-2009 07:16 AM
grand wagoneer tailgate window stuck! jodyjeep Full Size Jeep Forum 2 03-03-2008 06:25 PM
88 Wagoneer stuck in 4 wheel drive? riffjeep Full Size Jeep Forum 1 08-20-2004 08:11 PM
