Dome light help! - Page 2 - JeepForum.com
post #16 of 22 Old 02-11-2013, 09:40 AM Thread Starter
jeepdj5
1982 FSJ Cherokee
Originally Posted by Dave145
The wire should come from the fuse box, run under the door weatherstrip, enter at the bottom of the pillar behind the door, then exit out the top of the pillar. My guess is that the connector/wire at the bottom of the pillar broken or rotted.
So do I half to rip up my carpet?
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #17 of 22 Old 02-11-2013, 09:43 AM
Dave145
1976 FSJ Cherokee
No you don't really have to. Try pulling up the door weatherstripping a bit and see if you can see the wire.
Dave145 is offline
post #18 of 22 Old 02-11-2013, 09:47 AM Thread Starter
jeepdj5
1982 FSJ Cherokee
Ok I will try this!
jeepdj5 is offline
post #19 of 22 Old 02-11-2013, 10:53 AM
pleontks
1976 J-Series Truck
'A' Pillar is the roof support at the corner of the windshield and the door. 'B' Pillar is the roof support behind the door. 'C' Pillar is the next one back, etc..
On a side note, you should probably pull your carpet and start on your floor rust repairing. Hopefully it's not too much.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #20 of 22 Old 02-11-2013, 11:06 AM Thread Starter
jeepdj5
1982 FSJ Cherokee
Floor is rusted out, my feet sit on the transfer case
jeepdj5 is offline
post #21 of 22 Old 02-11-2013, 11:07 AM Thread Starter
jeepdj5
1982 FSJ Cherokee
I'm going to fix the dome lights and drive it it's my first car, truck JEEP!
jeepdj5 is offline
post #22 of 22 Old 02-11-2013, 02:37 PM
pleontks
1976 J-Series Truck
When I did my inside lights, I grounded everything, then ran the 12v thru a toggle. That way, they're on when I want, and not just because the door is open.
pleontks is offline
