Does my Dana 44 does it have Tru Trac? - JeepForum.com
post #1 of 14 Old 06-18-2013, 06:15 PM Thread Starter
Warakee
1976 FSJ Wagoneer
Hello! I am new to this Jeep Forum I have a 1976 Jeep Wagoneer with a 360 Quadra-trac. When I pulled her out of storage this year I noticed the rear diff was leaking, I am unsure if I have the Truetrac rear end as from my understanding would require Limited Slip additive. The Tag# 5356009 46-13 3.54. I believe it to be the Dana 44 Rear end.
Warakee is offline
post #2 of 14 Old 06-18-2013, 07:26 PM
pleontks
1976 J-Series Truck
If it does, there should be another tag on the axle saying so.
It probably is not, but someone could have switched it at some point, and not put the tag on. I'd say open it up and see. Very easy to see the difference once you open the diff.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 14 Old 06-18-2013, 07:51 PM Thread Starter
Warakee
1976 FSJ Wagoneer
I did have it open, and it appeared to have spider gears, that would mean it is not the True trac correct? I also assume it does not have Truetrac, I am not familiar with rear ends, and advise would be great thanks!
Warakee is offline
post #4 of 14 Old 06-18-2013, 07:59 PM
lucdog
lucdog's Avatar
1980 CJ5
The Detroit truetrac uses standard gear oil, no additive needed. If you see spider gears, it's not a Truetrac . Didn't jeep call the OEM a tracloc?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #5 of 14 Old 06-18-2013, 08:09 PM
1shotwonder
If it looks like this inside your cover then you have somekind of locker/truetrac.. If it doesn't look like this, then you have spider gears..
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #6 of 14 Old 06-18-2013, 11:58 PM Thread Starter
Warakee
1976 FSJ Wagoneer
Thank you! I do NOT have a "Trac-Loc" then. I appreciate the help. No Friction additive needed. New to the forum!
Warakee is offline
post #7 of 14 Old 06-19-2013, 01:13 AM
pleontks
1976 J-Series Truck
I've got a tracloc or whatever it's called from a 79 chief in mine. The open had a tapered housing for the spider gears, whereas the tracloc had a squared off case, like the locker, but with visible gears inside.
pleontks is offline
post #8 of 14 Old 06-19-2013, 10:10 AM
super98lsc
Quick way to tell jack up rear spin tires if you spin one tire foward and the other rotates backwards= open rear end.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #9 of 14 Old 08-04-2013, 01:07 AM
cometthedog
And if the opposite side does nothing?
cometthedog is offline
post #10 of 14 Old 08-04-2013, 06:02 AM
RockRollin
1990 FSJ Wagoneer
Is the drive shaft turning?
If both tires are off the ground, spin one, if the other tire does not move, and the drive shaft does not move. Then you have something broken in the rear end (spider gear, clutch, axle shaft)
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #11 of 14 Old 08-04-2013, 06:11 AM
cometthedog
Nothing broke. Just happened to have it up on stands and spun the right rear tire. Im used to seeing the opposite side turn the other direction but this thing does not. In the gravel both tires spin. Im gunna look at the tag when it gets light out. I should add I just recently bought this rig two weeks ago not running. Tune up new battery and a carb rebuild and we were driving. Still needs work as with everything I own.
post #12 of 14 Old 08-04-2013, 07:15 AM
RockRollin
1990 FSJ Wagoneer
My trac loc hardly moves before the other side spins, maybe an inch at the tread surface. Even then the drive shaft begins to spin and stops in park.
The rotation of the tire has to have a counter action in the drive line.
"I like fun" Edd
post #13 of 14 Old 08-04-2013, 12:44 PM
super98lsc
Correct. Put Trans in park or in 1st if manual. if its an open rear the tires will rotate opposite each other. If same direction its an LSD. If other tire does nothing then likely its a shot LSD and needs new clutches. Assuming its not major part failure as Rock mentioned.
post #14 of 14 Old 08-04-2013, 07:36 PM
cometthedog
Mines open. :-(
