Do it myself or have a shop??? - JeepForum.com
post #1 of 8 Old 04-07-2010, 07:06 PM Thread Starter
bill3
1981 J-Series Truck
I changed out my rear end out awhile back from a AMC 20 to a Chevy 10 bolt with 3.73's and a factory locker. Iíve since learned that the AMC 20 would have been a better and stronger rear end if I had changed to solid axles. Oh well live and learn. Iím not sure of the gears in the front and know I canít put it into 4wd till I know that they are the same front and rear. I've been told that 3.73's in a j10 factory are rear. So I'm going to check this weekend and see whats in the front. I have checked around and it looks to be round $500 to $600 to have a shop change my gears. I have found a set of 3.73 gears for $100 and 4x4 parts has a master install kit for $91.95. Iím thinking of doing this myself, what do yall think? My dad has done it before on his stock car a long time ago and says itís not too hard. But his stock car didn't matter if they were alittle noisy. Heís on the fence weather to attempt it on my truck. His friend has the measuring tools to do it. Itíd save me some money and I would learn how to do it. Plus I'd be able to change them to a 4.56 latter on if I switch back to 35's
LIFE IS TO SHORT FOR ANGRY PEOPLE
bill3 is offline
post #2 of 8 Old 04-07-2010, 08:26 PM
BJ's Off-Road
1979 FSJ Cherokee
I answered your post on IFSJA as well.
Just so you know, we can get anything 4wheel parts has but cheaper...
www.bjsoffroad.com
BJ's Off-Road is offline
post #3 of 8 Old 04-07-2010, 10:04 PM Thread Starter
bill3
1981 J-Series Truck
I'll be calling you tomorrow
bill3 is offline
post #4 of 8 Old 04-08-2010, 08:20 AM
CSP
A fullsize Jeep AMC 20 already has one-piece axles. It's the CJ version of the 20 that is problematic.
CSP is offline
post #5 of 8 Old 04-08-2010, 08:24 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
It has 2-piece welded axle shafts from the factory, but the point is still valid. You don't need to change them out until you exceed the 36" tire range and run a good amount of power. The FSJ AMC20 housing is much stronger, as well. Bigger tubes, pressed in farther, etc.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #6 of 8 Old 04-08-2010, 08:22 PM Thread Starter
bill3
1981 J-Series Truck
I will keep an eye out for a nother one then. Rite now I just want to be able to use my 4wd.
bill3 is offline
post #7 of 8 Old 04-08-2010, 11:19 PM
PavementPounder
Cool as Ice...
Here's the pic of the factory-welded 2pc FSJ AMC 20 shaft:
post #8 of 8 Old 04-09-2010, 07:07 PM Thread Starter
bill3
1981 J-Series Truck
POWER I HAVE And I'm never going to run more than 35x15.50x15's. But honestly when I do upgrade I'm going to go with 1 ton's But thats in the future. Have other issues to dill with first.
Well I've decided to leave the front axle to the shop. I started adding up everything and I'm at half the price with no warranty . Plus thatís with a used factory 3.73. I talked to the shop and he's installing an aftermarket ring and pinion. They also can have it done for me the same day if I drop it off in the morning at the latest the next day. Pop was saying that itís going to take us all weekend to do at the house and no warranties So no giving up that second job for now
bill3 is offline
