diy alingnment - JeepForum.com
post #1 of 5 Old 04-05-2013, 03:04 PM Thread Starter
cookingguy
1979 FSJ Cherokee
diy alingnment
So i am doing a new tie rod and end tomorrow and need to know how to do an alignment
On my 79 cherokee.
cookingguy is offline
post #2 of 5 Old 04-05-2013, 03:18 PM
RockRollin
1990 FSJ Wagoneer
Jeep specifies a toe-in of 3/64 to 3/32 of an inch.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 5 Old 04-05-2013, 04:51 PM Thread Starter
cookingguy
1979 FSJ Cherokee
Ok so how do i go about adjusting so i get those specs
post #4 of 5 Old 04-05-2013, 05:45 PM
revelc
1985 FSJ Wagoneer
Measure mid way up both tires. Mark the exact halfway point with chalk.
Then find the exact center of the tire facing the front and the rear( as well as you can ). Width and height wise.
Then measure from the center to center facing the front, then facing from the rear of the vehicle.
To adjust the toe-in toe-out loosen the bolts on your drag link and rotate it to adjust toe. When they are good to go tighten it up.
This is how they taught us to do alignments in the field when I was in the Air Force.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #5 of 5 Old 04-05-2013, 05:48 PM
RockRollin
1990 FSJ Wagoneer
Jack up front, mark a spot on tread each tire. Set marks to front, level with the c/l of hub Measure distance between marks, rotate tires so marks are at rear, measure again. Calculate average. Set toe in so the front measurement is shorter than the average within the tolerance above
"I like fun" Edd
