Ditch the Vacuum - JeepForum.com
post #1 of 11 Old 03-01-2013, 09:04 AM Thread Starter
KC87Wagoneer
1987 FSJ Wagoneer
Ditch the Vacuum
I have an 1987 Grand Wagoneer and I am updating the Carb and Intake to Edelbrock performer and the 1406. This is the non EGR package. I hate Vacuum. My last rebuild, a CA built 66 mustang with emmisions had one vacuum line on it when I was done.
I want to know what I have to keep and what I can trash. Please keep in mind that for this beast I do not want to kill my MPG either and would rather keep more vacuum that sacrafice fuel efficiency. My GW does not have a smog pump, was not CA built but still has a ton of vacuum. I know I have competing motives here so I am looking for advice from someone who has removed their own vacuum lines to tell me what can go and what the MPG difference was.
Thank you,
KC87Wagoneer is offline
post #2 of 11 Old 03-01-2013, 09:07 AM
jeepdj5
1982 FSJ Cherokee
Trash every thing accept heat vacuum, and vacuum advance! And if it has working cruse I would keep that too, I'm only using one vacuum can/battery/holder what u macallit for my heat and cruse.
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #3 of 11 Old 03-01-2013, 09:37 AM
RockRollin
1990 FSJ Wagoneer
popular topic
http://www.jeepforum.com/forum/f57/v...73/index2.html
Must be cabin fever. This should cover most of your questions.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 11 Old 01-10-2014, 03:26 PM
mkimball72
1986 FSJ Wagoneer
Can I get a picture of a super simple vacuum setup that has zero emission control remaining. Want as close to zero vacuum lines as possible. Thanks
mkimball72 is offline
post #5 of 11 Old 01-14-2014, 01:15 PM
ChrisHager
Administrator
ChrisHager's Avatar
While these pictures aren't specifically of the vacuum lines, they do show minimal amounts of 'stuff' in the engine bay. I intend to clean it up a bit more as I go. I still need to remove the hose/lines that mount to the exhaust manifolds. I'm afraid to snap off a bolt though...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6 of 11 Old 01-17-2014, 01:51 PM
mkimball72
1986 FSJ Wagoneer
Pics didn't come thru.?
post #7 of 11 Old 01-17-2014, 02:00 PM
ChrisHager
Administrator
ChrisHager's Avatar
Weird. I can see them here. Anyone else having an issue?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 11 Old 01-19-2014, 10:26 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
When I put a 1987 engine in my 1973, the 87 engine was covered with a web of vacuum lines. CTO's everywhere.
I ended up using my 73 intake on it, which already had the EGR deleted, and all the smog crap was long gone. I believe the only vacuum I have no is the brake booster, the PCV, transmission modulator thing, HVAC and Advance for the dizzy.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #9 of 11 Old 01-21-2014, 06:58 PM
mkimball72
1986 FSJ Wagoneer
where did you run the vacuum advance?
post #10 of 11 Old 02-01-2014, 05:41 PM
mkimball72
1986 FSJ Wagoneer
I assume you run it off the carb. I have the stock 2 barrel. I currently have it run off the front right port (facing the engine).? Also, I've installd warn locking hubs on my 86. Do I still need to hit the vacuum switch when engaging the 4 wheel drive? I assume not.
post #11 of 11 Old 02-01-2014, 07:56 PM
RockRollin
1990 FSJ Wagoneer
Be absolutely, positive that you lock in the hubs BEFORE you engage 4wd, or you will be learning how to swap a transfer case. If 4wd is engaged and the hubs are not locked in, all the power will be going to the front (least resistance), and it will fry the viscous coupling in the transfer case.
"I like fun" Edd
edelbrock , grand wagoneer , vacuum
