dent in hood from power steering pump hitting hood. - JeepForum.com
post #1 of 20 Old 11-22-2012, 07:50 PM Thread Starter
luckywagoneer
1989 FSJ Wagoneer
Does anybody else have this problem the power steering pump hits the inside of the hood when i rev it up. There was I nice dent and I notived some rubbing well I beat the dent out I did bondo the spot smooth and pianted it well I did a burn out today and cracked the spot and piant where I fixed it what's the deal?
luckywagoneer is offline
post #2 of 20 Old 11-22-2012, 08:07 PM
pleontks
1976 J-Series Truck
i'd be checking the engine mount. maybe one's bad, allowing engine to lift up when torqued.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 20 Old 11-23-2012, 09:11 AM
BJ's Off-Road
1979 FSJ Cherokee
x2...
Pop the hood, start the engine, put it in gear, press the brake HARD and give it some gas and see if the engine moves a bunch, if it does your mounts are toast.
www.bjsoffroad.com
BJ's Off-Road is offline
post #4 of 20 Old 11-23-2012, 10:06 AM
olliehopnoodle
1982 FSJ Cherokee
Yep, broken mount. The dent in the hood is not 'uncommon'.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #5 of 20 Old 11-23-2012, 10:44 AM Thread Starter
luckywagoneer
1989 FSJ Wagoneer
Looks like I need to fix this is there a way I can do one at a time by jacking one side at a time never done this before.
post #6 of 20 Old 11-26-2012, 08:22 AM
jeepdj5
1982 FSJ Cherokee
Just spot doing burnouts! Tires are expensive any way, I would just mush the power steering cap a little
jeepdj5 is offline
post #7 of 20 Old 11-26-2012, 01:38 PM Thread Starter
luckywagoneer
1989 FSJ Wagoneer
Lol that's my way of getting new tires and I would mush it down the guys at the parts store siad that I can lift one side at a time to put some new ones in.
post #8 of 20 Old 11-26-2012, 03:49 PM
jeepdj5
1982 FSJ Cherokee
Ok but burnouts kill drive train and brakes
jeepdj5 is offline
post #9 of 20 Old 11-28-2012, 09:20 PM
jeepdj5
1982 FSJ Cherokee
Well
Sent from my fsj Cherokee touch using JeepForum
jeepdj5 is offline
post #10 of 20 Old 11-29-2012, 07:43 AM
muddy93
1987 FSJ Wagoneer
If the motor mounts are that bad, I'd be checking the trans mount too. chances are, it's going to need replaced as well.
Yes, you can change them one side at a time. If I remember correctly, it was the passanger side on mine that gave me issues when trying to put the new mount in. I think I had to loosen the starter (or maybe jsut the wires) to get a little extra clearance to get the mount in place.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #11 of 20 Old 11-29-2012, 04:41 PM
1983Chief
Burnouts are what jeeps were designed for. all you need is a GM drivetrain and you'll be fine haha
1983Chief is offline
post #12 of 20 Old 11-29-2012, 04:49 PM
rd94yj
Post a vid of the jeep doing burnouts!
94 YJ 60/14 bolt 4.0 ax15 Dana 300
88 YJ 60/14 bolt AMC 360 nv4500 np241
rd94yj is offline
post #13 of 20 Old 11-29-2012, 05:12 PM
1983Chief
i will once i get my tranny back together haha the mud runied it, not burnouts. i have the a MTX 350 in mine and an aussie locker and it'll keep doing doughnuts until it runs out of gas
post #14 of 20 Old 11-29-2012, 05:54 PM
jeepdj5
1982 FSJ Cherokee
Dude I have an 82 chief
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #15 of 20 Old 11-29-2012, 05:54 PM
jeepdj5
1982 FSJ Cherokee
In the mud sand and off pavement!
jeepdj5 is offline
