Dana 60 locker. only found one. more? - JeepForum.com
post #1 of 9 Old 04-17-2011, 10:26 AM Thread Starter
Eric1080
1978 J-Series Truck
im looking to get a dana 60 locker for the rear of my jeep. axle came from a 74 j20. it has 30 spline shafts and a trac lock limited (very limited) slip. the only locker ive been able to find is the powertrax no-slip part #92-0460-3025. has anyone been able to find anything else or using something else cheaper??
Eric1080 is offline
post #2 of 9 Old 04-17-2011, 12:26 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
powr lok, trac lok, e locker, detroit locker, tru trac, ARB? a simple search netted these answers.......
jeepdaddy2000 is offline
post #3 of 9 Old 04-17-2011, 12:33 PM Thread Starter
Eric1080
1978 J-Series Truck
ok. ill redo my thread. looking for a lunchbox type locker that is reasonably priced and that i can install myself. found a couple different ones but they were for 35 spline or open type.
Eric1080 is offline
post #4 of 9 Old 04-17-2011, 04:21 PM
jeepdaddy2000
1971 CJ5
They do not make a lunch box locker for any Trac Lok applications. You will have to switch to an open carrier to install one or go with one of the above mentioned units.
post #5 of 9 Old 04-17-2011, 04:36 PM Thread Starter
Eric1080
1978 J-Series Truck
thats what i was afraid of. but an open locker requires a gear setup from a shop doesnt it?
Eric1080 is offline
post #6 of 9 Old 04-17-2011, 04:38 PM Thread Starter
Eric1080
1978 J-Series Truck
so i might as well get the powertrax no-slip
Eric1080 is offline
post #7 of 9 Old 04-17-2011, 08:07 PM
jeepdaddy2000
1971 CJ5
Run a picture and measure the backlash. When installing the new carrier, move the carrier shims till you get the original backlash reading. This should give you the same picture you had when you started. The procedure will require a way to pull and press the carrier bearings. BTW, this is the same procedure you will have to go through to install any carrier based LS.
post #8 of 9 Old 04-17-2011, 08:44 PM Thread Starter
Eric1080
1978 J-Series Truck
ive done a lunchbox but i have no idea what language your speaking. its currently above my level of skill. i need to study up on it better before i tear into it
Eric1080 is offline
post #9 of 9 Old 04-18-2011, 05:34 AM
jeepdaddy2000
1971 CJ5
It sounds impressive, however, it is actually quite simple. Do some research and when you feel good, give us a holler and we can walk you through it.
Found a creampuff... mhays Full Size Jeep Forum 4 03-08-2011 01:08 PM
found 74 J10 401 pretty cheap peaceofjeep Full Size Jeep Forum 7 02-26-2009 09:31 PM
I found a 70 cammando on craigslist SCsimpleman Full Size Jeep Forum 0 02-22-2009 06:33 AM
found another jeep 03fxsti Full Size Jeep Forum 1 03-21-2006 11:50 PM
79 J20 w/360 - Think I found my V-8 for my CJ - But Leaks Oil hfjeff Full Size Jeep Forum 5 11-13-2005 06:19 PM
