custom paint job and/or lined interior pics - JeepForum.com
post #1 of 15 Old 03-27-2013, 08:12 PM Thread Starter
Saul32
1988 FSJ Wagoneer
Any of y'all care to share your custom paint job or lined interior pics?
Please do so as I'm sure many of us would enjoy
Thanks
Nothing important...
Saul32 is offline
post #2 of 15 Old 03-27-2013, 08:20 PM
1983Chief
Spray paint
1983Chief is offline
post #3 of 15 Old 03-27-2013, 08:41 PM Thread Starter
Saul32
1988 FSJ Wagoneer
Freakin sweet! What product did you use? Is the headliner also lined?
Thanks
Saul32 is offline
post #4 of 15 Old 03-27-2013, 11:16 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
only lined the cargo area, i will line the rest when i replace the carpet. Also built new size panels out of Luan and built a cargo cover.
Al's Liner
This pic is how it looks after a year of use. Only wear is on the taigate where the latches on my tool box cut through it.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #5 of 15 Old 03-27-2013, 11:25 PM Thread Starter
Saul32
1988 FSJ Wagoneer
Thanks. It looks great. I'm thinking I"ll be tearing out my carpet next weekend if I finish my intake, carb, cam swap by this weekend.
Saul32 is offline
post #6 of 15 Old 03-28-2013, 04:55 AM
RockRollin
1990 FSJ Wagoneer
Al's Liner
Doc can you remove the cargo cover pretty easily
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #7 of 15 Old 03-28-2013, 09:08 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Yup. Has 2 wing nuts holding it to the fender wells and is held in by the slope of the tailgate at the other end. Undo the wing nuts lift it up at a funky angle and slide it out.
I have dimensions and whatnot if you want.
-Andrew
Marn is offline
post #8 of 15 Old 03-29-2013, 09:31 PM Thread Starter
Saul32
1988 FSJ Wagoneer
just found these pics today and thought I would share with
http://1.bp.blogspot.com/_egrUboeATR...h/DSC_3842.JPG
http://i245.photobucket.com/albums/g...4/IMG_1324.jpg
Saul32 is offline
post #9 of 15 Old 04-01-2013, 08:56 PM Thread Starter
Saul32
1988 FSJ Wagoneer
Anyone use monstaliner or herculiner? Also, how much noise is to be expected if removing carpet and replacing with liner?
Saul32 is offline
post #10 of 15 Old 04-01-2013, 10:17 PM
olliehopnoodle
1982 FSJ Cherokee
I picked up my rig with Rhino liner and diamond plate. It needed an outside paint job really bad. Red wasn't my first choice but I realized the 'A' pillar was color coded to the body. Add to that jambs, hood, tailgate, etc and I decided to go with 'red' but not the original color. I also had them paint the rear interior part.
No carpet is loud. But I have since loaded it up with totes full of stuff. ALso, I can turn the stereo up to 'eleven' to cover the noise.
The exterior is slightly custom. I went with the chief look but didn't do as low with the black as stock. I also kept the badging off:
Here is a good shot of the interior painted, the diamond plate and the non-repainted part of the tail gate. At a glace you don't notice the color is not the same:
Here is another shot show the color difference isn't too off. Also one of the amps that helps to cover the noise.
I made some panels to replace the diamond plate:
Again, you don't really notice the difference in the jamb color compare to the repainted interior. The floor/wheel wells are rhino lined. The panel is something I made and covered in vinyl
I did add some 'chief' badges. They are not in the stock location. I painted the red 's' to match the color of the jeep
And in the end, I added some custom 'arizona pin stripes'....
Most of them washed off... some didn't.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #11 of 15 Old 04-01-2013, 11:13 PM Thread Starter
Saul32
1988 FSJ Wagoneer
. I myself am not a huge red guy but your Cherokee is farkin BOSS my friend!!
Saul32 is offline
post #12 of 15 Old 04-02-2013, 03:09 AM
RockRollin
1990 FSJ Wagoneer
Dang it Ollie, every time you post pics of your Cherokee I come to, realizing that time has stood still and there is drool on my Android, its like SJ porn or something. Great looking rig
"I like fun" Edd
post #13 of 15 Old 04-02-2013, 07:34 AM
olliehopnoodle
1982 FSJ Cherokee
I really wanted to paint it the same 'dark copper' color as my wagoneer. It was factory but unusual and much more subtle. But I didn't want to not paint the jambs/hood/etc. It just became cost prohibitive.
So I embrased the red theme. Tool box, gas can, roll bar covers and even my tie down straps are red. I went red with the CB antenna and have a small red cooler but need to find a larger red one. You can see them in the pic:
I looked around for some red buckets but didn't have much luck.
The headliner is the next thing. You can see it in one of the pics. I am going to recover it. Probably in vinyl since it wipes off easy. Here in AZ dust is an issue. It's going to be a little bit of a bear to get out with the roll bar in place and I am considering adding some kind of overhead thing for some easy to reach switches. When I am strapped in with the harness I can't reach anything mounted to the dash. Mostly not a big deal but an ARB/Aux Light switch in reach would be nice. I am kicking around the idea of adding a tablet mount too and running power from the roof.
I also have some roof rack supports I need to add in so it won't just be a 'day' project.
post #14 of 15 Old 04-02-2013, 07:03 PM
super98lsc
Nice rig man! Wonder can you use the separator trim like in the wagoneers to make the headliner 2 pieces? Assuming its all one long one like my WJ.... Ugh that was a nightmare. Like that vinyl idea for the dust, Austin is bad w that too.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #15 of 15 Old 04-02-2013, 08:49 PM
olliehopnoodle
1982 FSJ Cherokee
Thanks. Yeah, it's two pieces. I might look for something black/red for one or the other sides. Kind of a cool accent. And maybe a few LED lights.
