Converting 1987 Grand Wagoneer to Diesel - JeepForum.com
post #1 of 11 Old 12-20-2010, 08:25 AM Thread Starter
jedelbrock
1987 FSJ Wagoneer
Hey Guys,
I am looking to switch my 1987 Grand Wagoneer over to a diesel engine. I know that some of you have done the conversion yourself and I was wondering if you could offer any helpful hints!
jedelbrock
jedelbrock is offline
post #2 of 11 Old 12-20-2010, 11:24 AM
Kevos97TJ
Can't be of much help myself... but hope to learn a thing or two from this thread!
"when in doubt... throttle out!"
1997 TJ, Citron Pearlcoat, AX-15, 4.0, D30/D35 open, 4.56s, 33 inch BFG T/A KOs on AEVs
2012 Patriot Sport 4X4 5speed - the new DD
my blog -
Kevos97TJ is offline
post #3 of 11 Old 12-25-2010, 01:54 PM
carnuck
1984 J-Series Truck
Check out John Meister's rig (sold a bit ago, but info is still up) John Meister - Copyright 1995 - 2010
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #4 of 11 Old 12-27-2010, 02:35 PM
sang_route
1989 MJ Comanche
Depends on how you want it set up and what is still good on ur wag.
1. If the frame has seen better days I'd say find a rolled dodge truck w the cumins turbo diesel and if you get really lucky the NV45000 manual trany. If you have access to a torch you can cut and splice the frame to fit but if not find one with a similar wheelbase.
2. dredge up the parts and fab some custom motor mounts for ither a 4 or 6bt. If you tow heavy loads or have 40's or something like that i'd use the 6 but if you just commute you could get away with the 4.
3. Try using a gm (as long as you don't have it screaming under a load all the time they are reliable) but I think you will need at least an adapter if not a another tranny.
4. Or if you so choose you can use a (shudder) ford diesel whatever.
I list these in the oder I would do them. Being a heavy equipment Tech. I tend not to trust the fords because I always see them to be in the work shop at regular intervals for things like engine fires and major internal breakages. How you split every piston in half in 6 months of driving... Sorry getting off topic.
Cafinaholics Anomous me and anyone that has way too much coffee in a day!
And yes I can't spell... Live!
88 and 95 XJ, 1973 J4000
sang_route is offline
post #5 of 11 Old 12-28-2010, 03:30 AM
carnuck
1984 J-Series Truck
I just found an '86 F250 4x4 with 7.3 for $900 (rusty box and dead auto trans)
FOR SALE STUFF
carnuck is offline
post #6 of 11 Old 12-28-2010, 05:20 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Ford 6.9/7.3 NA motors are cheap, plentiful, and very reliable. The V8 platform also keeps engine length down, helping engine bay fitment.
Just remember front spring upgrades are in the works as well, since Diesels are substantially heavier than their gas counterparts.
jeepdaddy2000 is offline
post #7 of 11 Old 12-31-2010, 07:42 PM
jeepdavetj
1991 XJ Cherokee
Speakin of this, does anyone have a parts list for swapin a 6.2/6.5 GM diesel into a Waggy? Its gonna be my next build.
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline
post #8 of 11 Old 01-03-2011, 09:28 PM
fuzz2010
Check out 4btswaps.com More than just Cummins there.
fuzz2010 is offline
post #9 of 11 Old 01-04-2011, 07:39 AM
cummins5552
Originally Posted by jedelbrock View Post
Hey Guys,
jedelbrock
what trans are you using?
cummins5552 is offline
post #10 of 11 Old 01-04-2011, 08:20 AM
BJ's Off-Road
1979 FSJ Cherokee
This is a pretty easy sway as the 6.2/6.5 bolt up the same as a GM engine.
After you get the mounts, you just need to adapt the transmission or probably easier would be to run the GM transmission and transfer case.
Of course you will have some wiring to do as well as throttle cable, radiator, etc.
www.bjsoffroad.com
BJ's Off-Road is offline
post #11 of 11 Old 01-04-2011, 08:24 AM
BJ's Off-Road
1979 FSJ Cherokee
Hey Guys,
jedelbrock
I just swapped my 1996 Suburban to a 6bt Cummins diesel. It was fairly straightforward, I put conversion mounts in, the Dodge radiator and intercooler (which took a lot of cutting of the core support), wiring, brackets, transmission adapter, etc, etc.
The easiest swap in terms of modification would be a non-intercooled 4bt. This would fit fairly easily front to back but might have some clearance around your differential (a lift would help). Most early 4bt's are a one wire hookup to make them run.
6.2/6.5 diesel would also be an easy swap that has been done and would make plenty of power for an FSJ.
You can google 4bt Grand Wagoneer and come up with lots of videos and forum posts, those people would be able to help out a lot.
Hope this helps.
www.bjsoffroad.com
conversion , diesel , diesel swap
1987 Jeep Grand Wagoneer info wanted. (ad included) kingplay334 Full Size Jeep Forum 4 12-04-2010 05:48 PM
1987 Wagoneer Alacran Full Size Jeep Forum 2 06-11-2010 11:56 AM
Cannot locate neutral safety switch on 1987 Grand Wagoneer jedelbrock Full Size Jeep Forum 1 01-09-2010 06:54 PM
1987 Grand Wagoneer Flywheel problems patrromig82 Full Size Jeep Forum 1 04-01-2008 01:00 PM
1987 Grand Wagoneer (Questions Winter Driving And Help) 05CobaltSS Full Size Jeep Forum 0 11-07-2006 09:05 PM
