Considering this 4" skyjack lift - JeepForum.com
post #1 of 6 Old 01-16-2014, 09:13 PM Thread Starter
Gante
We'll, I am starting to look into a decent suspension lift for my Waggy 91. After having read all the other impacts on suspension and shaft modifications, I believe that I am inclined for a 4" suspension lift kit with a 1" body lift. I think this may allow me to fit 33" wheel, right? If not 31" for sure. Without all the other issues with shaft length modifications and steep angles issues.
I have read that skyjacker is well recommended by many members. I just wanted to check with some of you on your thoughts about this specific lift kit...
3.5-4” System for 74-91 Cherokee\Wagoneer 4WD Front & Rear Replacement Springs - SKY-JP45KS-N
Nitro Shocks
NOTES:
E9. Power Steering Models Only.
Gante is offline
post #2 of 6 Old 01-18-2014, 06:26 AM
BJ's Off-Road
1979 FSJ Cherokee
To get 33's you would need a 2" body lift with a 4" suspension. I would recommend BDS over Skyjacker but they are both nice lift kits.
www.bjsoffroad.com
BJ's Off-Road is offline
post #3 of 6 Old 01-18-2014, 07:15 AM
88wood
Last year I did the 4in lift from BDS and am very happy with the product and their customer service. I have read several places that you will need a 2in body lift to fit 33's if your planning on doing any wheeling at all. I personally prefer the stance and feel of my wagon on 31's. Good luck on the lift though. Be sure to soak the bolts in PB Blaster a couple of days in advance, that 25 years of grime and rust make it a real pain if you don't. Show your before and afters here too
88wood is offline
post #4 of 6 Old 01-18-2014, 08:51 AM
BJ's Off-Road
1979 FSJ Cherokee
Our shop truck has a BDS kit on it and I like it quite a lot. Here are some pics (you don't need Facebook to view these):
https://www.facebook.com/media/set/?...1&l=aaea23f18d
It has 35's on it but that is made possible because of the flares which the Grand Wagoneer doesn't have.
I have a pic of a 1988 GW with the 4" BDS and 31's on stock rims I will dig up and post.
www.bjsoffroad.com
post #5 of 6 Old 01-24-2014, 09:18 AM
Wifes_WK
I have a BJ's 6" lift. What shaft problems? I did have to get longer shackles for the front because they would over center. But works like a charm.
Wifes_WK is offline
post #6 of 6 Old 01-24-2014, 10:56 AM Thread Starter
Gante
I hear that you have to change shaft lengths and the angles of the shaft to the transfer case and/or axles are not ideal unless modified.
Gante is offline
