Quantcast Clutch linkage on a 78 cherokee - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Clutch linkage on a 78 cherokee
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 04-30-2009, 05:04 PM   #1
Karl_V
ok I'll try to keep this short. On my cherokee the slack adjuster under the dash broke.(it was probly broke for the past 11 years just run in on 2 remaining threads to hold it in place) After 3 days of searching and not finding one i broke down and took it to a machine shop. Where they welded the 2 halves back together. My question may be a little on the odd side but when i put the slack adjusr back in I went to atatch the linkage to the z bar and was amazed to find that it popped in place. Just to check so dont get stranded but is it really just P.F.M. that holds the clutch linkage or, am I missing parts and or some strange mystery of existance
I am way to sober to be working like this!
Dont underestimate the other guy he may be pulling you out later!
Karl_V is offline   Reply With Quote
Old 05-06-2009, 12:04 AM   #2
carnuck
1984 J-Series Truck
PFM? Not sure what that stands for?
carnuck is offline   Reply With Quote
Old 05-07-2009, 08:46 AM   #3
Karl_V
P.F.M. is a short P.C. way of saying Pure (use your imagination for the F) Magic
i did get the linkage under the dash welded back together and the linkage to the Z Bar seamed to snap into place so it is up and running at the time of this message any parts resources and or other things to look for would be helpful
Old 05-13-2009, 08:33 PM   #4
eastin82
1981 CJ5
u should have got at me ive got a 77 cherokee with all the goodies you could need exept engine and axles!
eastin82 is offline   Reply With Quote
Old 05-20-2009, 02:45 PM   #5
Karl_V
well my axles should be pretty well off i just did the wheel bearings yesterday
Glock Forum
