clunking noise when turning - JeepForum.com
post #1 of 2 Old 03-22-2013, 10:15 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So when I turn to the left my jeep makes a clunking type noise. I do need to change the axel shaft U joint on the passanger side doing that on sunday. could the ball joint on the driver side be going bad on me? How do I check that. How do I check the U joint on the driver side to see if that is going out? The only reason I know the passanger side is bad is because I can see the bearing caps are about to fall off.
cookingguy is offline
post #2 of 2 Old 03-23-2013, 06:33 AM
RockRollin
1990 FSJ Wagoneer
If its "clunking" when your rolling, axle u-joints, wheel bearings.
If its "clunking" when your still, ball joints, spring bushings, possibly tie rod but that's a far reach.
Jack it up and try to pull the bottom of the tire up. Get in there with a small pry bar and see what moves
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
