Clogged Fuel Filter in 40 miles - JeepForum.com
post #1 of 7 Old 02-04-2011, 02:33 PM Thread Starter
Learath
1977 FSJ Cherokee
Well after the new fuel pump, lines, and a few other parts. its still not leaking. but when i took it out to get a compressor from a guy today it bogged down and died on the way back. managed to limp it into a parts store. from how it was acting i figured it was the filter. turned out the new filter was clogged with a thick brown mud. banged it against the fender and go a bunch to come out of the "in" side. glad i put a filter in before the new fuel pump. the way it was plumbed before the only filter was after the pump.
these filters are cheap but i wonder if i should just keep changing them until they stop clogging or if i should try and clean out the tank some how.
Learath is offline
post #2 of 7 Old 02-04-2011, 02:53 PM
Eric1080
1978 J-Series Truck
i noticed your in canada so maybe dropping and cleaning the tank is outta the question for mid winter. but sounds like it needs it.
Eric1080 is offline
post #3 of 7 Old 02-04-2011, 03:13 PM Thread Starter
Learath
1977 FSJ Cherokee
U.S. actually. washinton, just across the river from portland.
figured dropping the tank would be the best option. i have never had a tank this full of junk though. i would think it might be easier to drain and filter from the hard lines from the tank. is there a screen in the tank?
Learath is offline
post #4 of 7 Old 02-04-2011, 04:23 PM
chris142
if it's that bad it needs to come out and be cleaned.
chris142 is offline
post #5 of 7 Old 02-05-2011, 11:34 AM
JrTjK
1978 FSJ Wagoneer
how old is the gas in there?? did the jeep sit for a long time, or is this only a recent problem?
JrTjK is offline
post #6 of 7 Old 02-05-2011, 11:51 AM Thread Starter
Learath
1977 FSJ Cherokee
i believe it sat for a while before i got it. this is probably the third tank its on. was spraying fuel from the busted pump and running as rich as it can when the fellow drove it to my place to check out the trade i gave him for it. and i had just filled up the tank with fresh fuel yesterday morning.
I had a thought about the timing of when it clogged. was while i was going on a decent uphill on the freeway. all the agitation, suction and slant may have moved the sludge to the pick up line in the tank.
Learath is offline
post #7 of 7 Old 02-05-2011, 12:05 PM
JeepOrvis97
JeepOrvis97's Avatar
Definitely drop the tank and clean it out, mine was very rusty inside and it kept clogging filters. Same think happened with my buddies CJ5, and I had to do the same thing with his tank.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
520 miles and $1,160 later... DuckBox Full Size Jeep Forum 1 03-20-2010 04:05 PM
Gladiator fuel delivery problem, not getting fuel gladman Full Size Jeep Forum 5 02-10-2010 11:09 AM
Replacing AMC 360 Fuel Filter. egoods Full Size Jeep Forum 4 01-23-2010 07:08 PM
WTB - Fuel Filler Hose and Fuel Vent Hose, 81 J10 Sportside DonC Full Size Jeep Forum 3 04-26-2009 08:31 PM
Fuel Filter on AMC 258 NavyMan Full Size Jeep Forum 4 02-16-2007 07:27 AM
