Clattering when hot - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Clattering when hot
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFAlloy usa heavy duty ball joint kitsROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 07-02-2014, 08:21 PM   #1
gpcl16
1988 FSJ Wagoneer
Clattering when hot
Just recently finished a rebuild for my '88. It runs okay, but I'm getting a clattering noise when the engine is fully warmed up, i.e. run for at least 15 minutes. It does not sound like lifter ticking, more of a bad clattering noise that follows RPM and gets worse at higher RPMs. It seems to be coming from the passenger side valve cover but I honestly can't tell for sure. Seems like maybe the valves have too much clearance when they warm up??? Doesn't valve clearance usually go down as the engine warms up???
I thought perhaps the 10w-30 I was using was thinning out and not getting enough oil to the lifters so I changed to 20w-50 with a bottle of Lucas oil stabilizer and not much of a change. I'm also running a bottle of lucas break in additive.
The engine had 191,000 miles and had never been apart. It was surprisingly clean inside. I did find a flat cam though. I went .030" over and went for a pretty stock rebuild besides using a Melling Torque Cam. The valve seats and valves cleaned up nicely and easily so I only took about .008" off the valve stems. The cam and lifters specified an installed height, which was right on the money when I assembled the heads. I don't have too much experience with checking the lifter preload but it seemed like the pushrods were about in the middle of the lifter.
I torqued all of the rocker arm bridges to spec. Does that need to be done with the valve on the base circle of the cam, because I just torqued them all down with the engine in one position.
Anyways, any advice is appreciated. Thanks!
1988 Jeep Grand Wagoneer 4x4
360 V8, Torqueflight 727 Auto Trans
Dana 44s 3.31, Rear TrueTrac
gpcl16 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2014, 10:33 PM   #2
super98lsc
Sounds like ignition timing. Back off the total timing a few degrees. 3-4 and test. As the engine heat soaks over advanced timing will cause detonation and destroy the engine. What's your base timing and total timing at? A short duration cam will (typical for a torque cam) will bleed off less cylinder pressure making the dynamic compression ratio higher. That combined with the .030 overbore, any milling of the deck and heads and or thinner head gaskets can add static compression which of course also adds to the DCR. Might also dump a bottle of octane booster and top it off with 93 octane and see how it runs. I would keep total timing at no more than 32 degrees until you have it all sorted then experiment with more depending on your altitude and jetting. A lean mix will detonate easier than a rich mix etc.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline   Reply With Quote Quick reply to this message
Unread 07-02-2014, 10:48 PM   #3
XJTexas
All very good advice!!!
XJTexas is offline   Reply With Quote Quick reply to this message
Unread 07-04-2014, 10:59 PM   #4
gpcl16
1988 FSJ Wagoneer
I seriously doubt that it's a spark related knock. The noise happens at all times, regardless of load. It even happens in park when revving the engine. My timing is set at 12 degrees with vac disconnected. The noise seems to be running at crankshaft speed. I'm thinking piston slapping???
Unread 07-04-2014, 11:45 PM   #5
super98lsc
Piston clatter will be worse cold until the piston expands to the bore then it will quiet down or go away completely. If it's and exhaust leak use a piece of 1/2 diameter hose as a stethoscope and run it along the header gasket. May be one cylinder leaking clacking away. Pull a rocker and check the lifters. Fire it up for a second with the cover off you will know which one it is in seconds if it's a lifter/rocker/cam lobe wiped out. (Hopefully not)
www.mangierisrc.com
Unread 07-05-2014, 01:40 PM   #6
XJTexas
Might want to check your flex plate bolts also!!! These get loose and can sound similar to a piston slap or rod knock. Pull the lower bell housing cover/access plate and see if they are loose. Normally sounds like it is coming from behind the starter. Hope this helps & you find your problem soon.
Unread 07-05-2014, 08:26 PM   #7
carnuck
1984 J-Series Truck
^This. You'd be surprised how many "blown motors" were just the cover being hit by converter bolts!
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote Quick reply to this message
Unread 07-05-2014, 08:28 PM   #8
XJTexas
BTW:
I always set valves on TDC for each cylinder to ensure the valve train is on the base circle of the cam lobe for that cylinder. Might want to recheck your valve settings also.
Unread 07-05-2014, 10:19 PM   #9
super98lsc
Flex plate bolts good call. Been there man that is a sick feeling then you find the flex plate cracked or the loose bolts and rejoice rofl.
www.mangierisrc.com
Unread 07-06-2014, 04:00 PM   #10
XJTexas
I wasn't so lucky on my 2001 XJ ;-(
Unread 07-07-2014, 11:51 AM   #11
gpcl16
1988 FSJ Wagoneer
Thanks for the advice. I'll check out those things. Will probably be a few days before I have time for it though.
Unread 07-23-2014, 07:04 PM   #12
gpcl16
1988 FSJ Wagoneer
Sorry have been slow to update. I took my jeep in the other day to have a more experienced pro diagnose the noise. First of all, the noise seems to be crankshaft speed, bottom end, and coming from the front end of the engine (which likely rules out a cracked flex plate or torque converter bolts). We did a power balance test and determined that cutting cylinders made no difference to the noise, so a rod bearing, piston pin, etc are unlikely as well. His professional opinion is that the front main bearing got wiped out somehow. Next step is to pull the oil pan and remove the main bearing cap to inspect and plastigauge the front mains, and the others as well. I will definitely pull the inspection cover and check the bolts as well though before pulling the oil pan.
If the only problem is indeed the front main bearing, I'm considering buying a bearing set and replacing it in the jeep. I know it's generally best to just pull the engine and do it right but the engine only has about 75 miles on it since the rebuild, and otherwise runs great. I had the crank ground 10 under while it was apart. And I'm honestly not very interested in pulling/reinstalling that engine again... Has anyone attempted to replace main bearings without removing the engine before. I've been told that it can be done. Can you just loosen the main and rod bearings and fish the bearings out? Does the timing set/ torque converter need to be disconnected?
Unread 07-25-2014, 08:29 AM   #13
GCX2450
1989 FSJ Wagoneer
Did you get a new timing cover or reuse the old one?
I just replaced the oil pan gasket on my rebuild a couple weeks ago because the 1st cork gasket squeezed out right at the back of the engine and made it seem like the rear seal was pumping oil out. I was unable to get my oil pan out which would make your task very difficult. My issue may have been corrected by supporting the vehicle by the frame and letting the suspension droop, but I'm not sure. I did it on an 89 Toyota once, but it was a terrible PITA and I wished I had pulled the engine out by the time I was done. Also, you probably won't be able to completely inspect all the parts unless you're willing to drop the transmission out so you can remove the crank. If it's just a bad bearing and the cranks ok then you may be alright. Good luck with it. It's the worst feeling in the world to have a fresh rebuild go bad.
GCX2450 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2014, 08:52 AM   #14
super98lsc
I have done rod bearings and rod and piston swaps with the engine in place removing the mains might be a bit tougher. Unbolt the flex plate from converter. Then loosen all the main caps that should allow the crank to loosen/clearance to replace bearings. But if it spun one well you will be pulling engine anyhow. :-/ sorry for the crap luck. Your certain it's not the timing set hitting on something and presume noise is same with belts on or off?
www.mangierisrc.com
Unread 07-25-2014, 12:55 PM   #15
cometthedog
I was able to remove the oil pan in vehicle with the tires on the ground. 88 wagoneer. Had to remove the inspection cover on bell housing as it was over the lip of the oil pan. Easy peazy
cometthedog is offline   Reply With Quote Quick reply to this message
