caster - JeepForum.com
post #1 of 4 Old 09-16-2002, 12:31 PM Thread Starter
blackjeep
caster
do any of you guys know the caster angle on a 86 wagoneer axle. for some reason i am thinking it is zero degrees. It is in my wrangler now and is obviously not right because my steering is not returning to center and also doesnt handle well. Any ideas
blackjeep is offline
post #2 of 4 Old 09-16-2002, 08:44 PM
V-TWINTECH
Howdy. I believe the caster is 7 degrees. We are talking knuckle on the tube right?
2000 TJ
Bunch of crap that works.
Soon to add more and bigger crap.
V-TWINTECH is offline
post #3 of 4 Old 09-16-2002, 08:51 PM
CSP
They "should" be at about 6-8 degrees positive. I say "should" because they aren't always. The last one that I narrowed sat at zero with the spring perches level. Of course the spring perches aren't always level when they're attached to the springs, so that really is a good thing to rely on. Your best bet is to check it yourself with an angle finder or let an alignment shop tell you.
CSP is offline
post #4 of 4 Old 09-17-2002, 01:47 PM Thread Starter
blackjeep
Thanks, i guess i really should get an angle finder. I was just wandering because my steering isnt right and wandered if that could be the problem.
Stock '81 Cherokee Caster Angle? AgitatedPancake Full Size Jeep Forum 4 05-29-2007 06:10 PM
