carter afb 9635 - JeepForum.com
post #1 of 4 Old 03-30-2010, 08:35 PM Thread Starter
Kris82
1976 FSJ Wagoneer
carter afb 9635
just picked up a refurbished one online, anyway i was wondering if anyone has done that conversion? i picked up an adapter for it a edelbrock 2696.. do i need to pick anything up to get her going tomorrow when it comes in the mail? anything else that i'm forgetting? thanks for your help... hopefully the last upgrade needed to get ready for the summer camping and 4 wheeling...
Kris82 is offline
post #2 of 4 Old 03-31-2010, 09:54 PM
AMX
1991 XJ Cherokee
The adapter you got is for a Quadrajet or Thermo-quad. Those carbs have the primary venturies spread further apart than a Jeep spreadbore so that adapter wont match up with the Jeep spreadbore intake. You could use Edel. #8723 which is a 1/2" tall 4 hole wood fiber spacer. Or #8724 which is an 1/2" thick open center wood fiber spacer. The wood fiber spacers will help isolate the carb from the engine heat.
I think Trans-Dapt has an adapter specficly for the Jeep (Motorcraft) spread bore intake to the AFB Carb.
Dennis
AMX is offline
post #3 of 4 Old 04-12-2010, 06:52 PM
colojeepguy
1970 CJ5
This would be the one you need-
Trans Dapt Performance Products - 2199
colojeepguy is offline
post #4 of 4 Old 04-13-2010, 04:44 PM Thread Starter
Kris82
1976 FSJ Wagoneer
thanks for all your help, i ordered up that adapter and it works great, now the only issue is that my throttle is sticking, not going back to the starting point, so i need to work on that, got new springs and that didn't work, so hopefully I can figure this out soon, the carb works great and she's running like a charm now! (well other than that throttle sticking)
Kris82 is offline
