Carb Issue- 2150fuel feedback - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Carb Issue- 2150fuel feedback
Jeep Wrangler Complete Gear Upgrade Kits with Installs andRIGID LED Light Blowout Sale - All Sizes, All Series, all FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-16-2015, 04:05 PM   #1
Brrrian1
1990 FSJ Wagoneer
1990 GW 85k miles
My mechanic tells me the 2150a carb is great except the fuel feedback feature is messing up and causing stalling/cutting off. It's pretty new. Acc Pump and Power Valve are ok. He says to find one without that feature. Starts and idles great.
Any recommendations on finding such a one or how to fix or adapt the one I have?
I have to either feather the gas pedal or punch it a bit at which time there's a good chance it stalls and I'm left sitting across the road trying to turn left.
I'd rather not go spend the coin at this time to convert to a 4 barrel carb and intake etc.
Thank for reply (ies)
Brian
Brrrian1 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 04:16 PM   #2
lindel
Fuel feedback? Not familiar with that feature on the 2150 carb. It has an altitude compensation circuit, but that isn't likely to be your problem. My guess would be that the Accelerator pump needs to be adjusted correctly, and I would take another look at the power valve.
It could also be that the float level needs to be adjusted.
Lindel
His: 1999 TJ Sport
Hers: 1987 Grand Wagoneer
lindel is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 04:39 PM   #3
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Nope
no fuel feedback that I know of. As suggested, PV or Acceleration pump. Maybe crusty/russty Internals. The only anything electric hooked to the carb other than choke would be throttle solinoid, and thats only there to prevent dieseling
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 04:45 PM   #4
Brrrian1
1990 FSJ Wagoneer
there is a feedback solenoid. 2150a
thx for comments
Brian
South Carolina
Unread 02-16-2015, 05:21 PM   #5
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
There is a anti deiseling solinoid mounted on the same bracket as the throttle. It is NOT part of the carb.
Feedback....no. it does nothing at all to control the carb under normal Conditions. It is there to snap close the throttle plate and kill the engine. Cut the wire, take it off, throw it away, reset your idle speed.
"I like fun" Edd
Unread 02-16-2015, 07:37 PM   #6
Brrrian1
1990 FSJ Wagoneer
thx RockRollin. just black wire in pic and remove right?
So I would then guess back to all the other potential issues to go through.
Thx for comments.
Brian
Unread 02-16-2015, 08:44 PM   #7
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Thats it. Maybe some more info on the exact "shut off" scenario, we could dial you in a bit closer to the problem
"I like fun" Edd
Unread 02-16-2015, 08:55 PM   #8
gpcl16
1988 FSJ Wagoneer
x3 on accelerator pump. Those are classic symptoms you described. Just because it's new, doesn't mean it's not defective, installed improperly, or needs adjustment. I'm betting either that or bad vacuum leak. I've had trouble with multiple 2150 carbs sealing at the back of the baseplate, underneath the altitude compensator.
1988 Jeep Grand Wagoneer V-8
Dana 44s 3.31, Rear TrueTrac
4" BDS All-Suspension Lift
gpcl16 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 03:19 PM   #9
Brrrian1
1990 FSJ Wagoneer
That pic I uploaded a few messages ago is called the Throttle Positioner Assembly in the Haynes Repair Manual page 4-12.
Is that the same as the fuel feedback solenoid that's not part of the carb ? It was identified as that in earlier reply.
Just want to make sure. See previous pic.
I got the rebuild kit and gaskets etc today. Should find the time to rebuild and go through vacuum again by Sunday.
Unread 02-18-2015, 04:18 PM   #10
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Yea same thing
"I like fun" Edd
