brake issue. - JeepForum.com
post #1 of 3 Old 05-15-2007, 08:59 PM Thread Starter
tdoshi9
brake issue.
i can't get the rear drums off of my 69 wagoneer. i just picked it up and the rear brakes are shot... i hear them grinding. so i know i will need new drums and maybe all the internals. but first i have to just get the drums off. i have tried taping with hammer.... prying it with a bar.... pb blaster... im out of options... maybe i am just dumb and don't know about something.... the drum should just slid off right? the front did with no problem. it has a dana 44 on it i believe but im not even sure about that. research is min on the internet about this sweet ride. so im here hoping that you guys with them can shed some light on how to get the drums off. and if you know where any info is i could read up on this car so i know more about it please send me a link... thanks guys
2006 KJ SPORT "WIFES"
1988 YJ 3.5 LIFT WITH 31'S. "MINE"
1969 WAGONEER 350 AUTO 4X4 "NEW TOY"
tdoshi9 is offline
post #2 of 3 Old 05-17-2007, 07:45 AM
J4GRAND
If this Wag has the two-piece Dana 44s on the rear, you need to remove the large nut in the center of the drum. If you have a normal 44, try to access the adjuster through the backing plate to back off the brake shoes.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline
post #3 of 3 Old 05-17-2007, 09:28 AM
carnuck
1984 J-Series Truck
Does the drum move at all? If not, Whack the drum really hard on the face (part that mates against the wheel) near the corner (but not on it!) of the drum. That should crack it loose from the center hub if it's not riveted to the hub. If it is riveted, you can cut the heads off with a chisel and take the drum separate. (I've had to do a few of those, including my '73 J4000 and my son's '68 Wag)
carnuck is offline
Anyone have a starting issue like this???? megajeep Full Size Jeep Forum 16 08-27-2009 11:21 PM
Wagoneer Alternator Issue ChrisKonzen Full Size Jeep Forum 1 04-08-2008 05:25 PM
Ball Joint Issue godplayer Full Size Jeep Forum 0 07-31-2007 03:49 AM
Ball Joint Issue godplayer Full Size Jeep Forum 0 07-31-2007 03:47 AM
Need help with starting issue stone5150 Full Size Jeep Forum 2 07-25-2004 11:26 PM
