Blower Fan Not Usually Working - JeepForum.com
post #1 of 6 Old 02-02-2011, 10:51 AM Thread Starter
DrHicks
1994 ZJ
Hey All ~
I recently bought an 89 Grand Wagoneer that's in remarkably good condition. There's one problem it has developed.
Yesterday the blower motor didn't start up when I started the Jeep, but came on shortly thereafter. This morning it did the same thing. Now it's not working at all.
The odd thing is that when I move the lever to AC, the blower motor comes on and runs as it should. But when it's on "heat" or "heat/defrost" or "defrost" the blower doesn't run.
Anybody got any great answers for this one?
THANKS!
DrHicks is offline
post #2 of 6 Old 02-02-2011, 05:59 PM
ndm06
1989 FSJ Wagoneer
The AC and Heater functions have separate blower motors. The AC is under the passenger side dash. The heater blower motor is under the hood next to the heater core. Is the blower not running at all or is air not coming out of the heat duct? If not running, check the electrical connections at the blower motor and also to the blower resistor which is attached to the heater core. The connections can sometimes come loose and also make sure you have a good ground connection. If the blower is running but no air is coming out it may be a vacuum issue as their is a vacuum controlled damper door that opens when the heat is on to allow the air to flow into the cab.
ndm06 is offline
post #3 of 6 Old 02-02-2011, 11:01 PM Thread Starter
DrHicks
1994 ZJ
^ Awesome. Thank you!
I began thinking it was probably the resistor, but I'll grub around the heater blower motor & connections first.
Speaking of the resistor - if that is what it turns out to be - how, exactly do I get to that beast?
DrHicks is offline
post #4 of 6 Old 02-03-2011, 08:19 AM Thread Starter
DrHicks
1994 ZJ
Did a little more exploring this morning.
It's the resistor.
Fortunately, the resistor is located on the engine side of the firewall, instead of under the dash. Very easy to get to. It'll be replaced this afternoon.
Thanks again!
By the way, why does this kind of thing always happen when it's flippin' -5 degrees, with 25 mph winds?!
DrHicks is offline
post #5 of 6 Old 02-03-2011, 04:53 PM
WagoneerCraig
1989 FSJ Wagoneer
Awesome . good to know . Thanks for sharing
WagoneerCraig is offline
post #6 of 6 Old 02-03-2011, 05:17 PM Thread Starter
DrHicks
1994 ZJ
Hey - it gets better.
Went to change out the resistor, and found out that it was just really dirty and corroded connections. Cleaned everything up, and we're in business.
So tomorrow I take back the $25 resistor (yes, OReilly's said specifically that I could if I never installed it.)
Cha-Ching.
DrHicks is offline
How can I tell if my 4wd is working? Pic included! MachPar Full Size Jeep Forum 13 01-16-2011 10:30 PM
heater blower??? FiremanBrad Full Size Jeep Forum 2 11-26-2010 08:10 AM
heater blower??? leebowles Full Size Jeep Forum 0 03-25-2010 09:15 AM
87 wago 4X4 not working where do i start 87redrum Full Size Jeep Forum 2 09-19-2009 10:20 PM
4wd not working G-MANtj Full Size Jeep Forum 1 12-08-2008 03:49 PM
