Blinkers wont work. - JeepForum.com
post #1 of 4 Old 04-05-2011, 09:50 AM Thread Starter
WoodyMS
Blinkers wont work.
Please help with a problem.
My blinkers will not work. Fuse is blown in turn signal slot. Hazards work fine. Fuse blows when key turned on and without using blinkers. There is 11.5 V present at the turn signal fuse panel. No obvious corroded wires under hood - haven't got to them all. PO wired a 2G battery cutoff wire and switch to the dash - that I have removed.
Any ideas?
WoodyMS is offline
post #2 of 4 Old 04-05-2011, 11:05 AM
jmw72
try removing the flasher and see if the fuse blows with it out. you should also check to see if you are grounding out. You can check that with a meter.
jmw72 is offline
post #3 of 4 Old 04-05-2011, 11:10 AM
Smallz
Have you checked the blinker fluid? You can get some new fluid from this site:
http://kalecoauto.com/index.php?main...&products_id=6
I'm sorry i couldn't resist.
Smallz is offline
post #4 of 4 Old 04-06-2011, 05:43 AM Thread Starter
WoodyMS
Tried to get the blinker fluid...sold out. On recheck, level was ok fluid a little dark.
Anyway, jmw72, how do I look for grounding out with meter?
Thanks
WoodyMS is offline
