Best lift for 35s on 82 wagoneer bougham - JeepForum.com
post #1 of 5 Old 09-07-2013, 08:23 PM Thread Starter
banjer1982
1973 CJ5
What would be the best way to lift a wagoneer to fit 35s for moderate trail use? Should I do a 6" lift with a body lift or I was thinking do a SOA/rear shackle conversion with a 2" suspension lift? I've never owned an fsj and actually bought the wagoneer for parts for my CJ but now I'm thinking maybe build the wagoneer
banjer1982 is offline
post #2 of 5 Old 09-08-2013, 08:25 AM
olliehopnoodle
1982 FSJ Cherokee
Welcome to the FSJ world.
For moderate trail use a 4" lift (springs) with some sliders and a locker is my typical recommendation. You can fit 31" tires in and if your truck came with the trailer package (3.31 gears) you won't have to regear.
If you want bigger tires then SOA/SF should be good for 33" tires and with a little spring lift or trimming 35's. You will want to regear.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #3 of 5 Old 09-08-2013, 04:29 PM Thread Starter
banjer1982
1973 CJ5
Thanks. I pick the Jeep up Tuesday and it needs a fuel sending unit and brake line. The gas tank is already pulled out so ill replace those and drive it for a while before I decide to make it a donor or keep it. I will probably keep it but I am not going to run anything less than 35s. I plan on regearing. The motor ran really well so I'm going to put off rebuilding that until after I do the suspension and other odds and ends
post #4 of 5 Old 09-09-2013, 09:47 AM
olliehopnoodle
1982 FSJ Cherokee
Ok excellent. Before you put the tank back in PB blast the heck out of the nut and then break it loose with a socket on both sides. If the nut/bolt are rusty replace them, or at least the nut, and tack it in place. Then when you do the lift you won't have to mess with it.
post #5 of 5 Old 09-09-2013, 12:59 PM Thread Starter
banjer1982
1973 CJ5
Ok thanks. I should go ahead and stock up on PB. I'm dreading all the old rusty bolts
