Belt Change? - JeepForum.com
post #1 of 4 Old 11-02-2002, 07:34 PM Thread Starter
Mr98Pontiac
Belt Change?
How in the world do I change the belt on an 89 4.0?
These motors are wayyyyy different than the GM's that im used to working on...........................
I see a belt tensioner under the power steering pump, which every way i turn it it still does not loosen the belt
Mr98Pontiac is offline
post #2 of 4 Old 11-04-2002, 08:19 AM
Kev
Master of the Obvious
Kev's Avatar
I can't speak from experience with your model, but when I've changed the serpentine belts I just put a wrench, socket, etc on the tensioner and pull it to take the pressure off and the old belt slides off. Does the tensioner move at all when you try to loosen it? Maybe it is froze up - you might be able to remove the bolts in the alternator or something to change it if you have enough room to work.
Hopefully someone else can post who has experienced a similar problem.
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #3 of 4 Old 11-04-2002, 08:34 AM
Jeepfreak81
Jeepfreak81's Avatar
I know on the 2.5 the tensioner is stationary and you move the power steering pump... well your supposed to.... there are like 4 bolts to loosen on it first... but with my 2.5 even then it doesnt move... i have resorted to pulling off the coil wire and having someone click it while carefully easing it on... but after yesterday i will never do that again...... (dont ask) even though thats how i have done it since i purchased the jeep...
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #4 of 4 Old 11-04-2002, 10:22 AM Thread Starter
Mr98Pontiac
Help!
I have tried everything............
Loosened every bolt on the power steering pump, tapped it with a hammer, you name it, I did it......Getting very frusterating...and the belt is torn halfway across & I dont wantt o be stranded
......someone has got to know...I cant find anything on the internet on how to do it, and I'm not about to spend $200 for the dealer to doit.......
Alex - AKA - Mr98Pontiac
2000 Chevy ZR2 4x4
http://www.imagestation.com/album/?id=4290613863
belt for 79 wagoneer for power steering blownmope Full Size Jeep Forum 2 11-29-2009 09:27 PM
serpentine belt system Scott00TJ Full Size Jeep Forum 1 08-06-2009 02:18 PM
Rear seat belt shoulder harness? sneedy Full Size Jeep Forum 3 06-20-2008 12:18 PM
New To Forun Drive Belt Problem WHIZZ Full Size Jeep Forum 1 08-27-2006 08:55 AM
Belt Snapped, need advice on how to replace rockymtnsports Full Size Jeep Forum 1 01-10-2006 12:50 PM
