battery drains overnight? - JeepForum.com
post #1 of 4 Old 03-28-2013, 01:01 PM Thread Starter
Wngnutz
1970 FSJ Wagoneer
need some help here....I have a 1970 wagoneer, put in a new battery and it is being drained within 24 hours. All things function properly. How do I go about figuring out what is draining the battery?
Wngnutz is offline
post #2 of 4 Old 03-28-2013, 01:28 PM
timgr
1975 CJ6
Use your multimeter to measure the number of amps between the battery cable and the battery. Then start removing fuses until the current drain stops. You can also disconnect the alternator and the regulator to see if that stops the drain. Once you broadly localize the drain, you can start refining your search to a smaller and smaller segment of the wiring harness. A '70 does have some fuses - they are inline with the wiring harness.
It helps to refer to the wiring diagram - http://oljeep.com/gw/elec/GW_wiring.html - the wiring in a '70 is simple by modern standards, but unfortunately there is no color code. I suggest you enlarge the diagram with a photocopier and start tracing out your circuits with color pencils. Be patient and systematic, and you will find the problem.
The '72 harness is similar to the '70. Look at it too, since it is shown in picture form. It may help you to locate things.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 4 Old 03-28-2013, 02:46 PM
super98lsc
Just another thought.... 1 more thing you might try is disconnecting the battery overnight and see if when you re-connect in the morning if it cranks. If its dead even without being connected then one of the cells has gone bad and its internally shorted. Will drain slowly overnight but as long as you start it multiple times a day it will turn over.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #4 of 4 Old 03-29-2013, 10:18 AM Thread Starter
Wngnutz
1970 FSJ Wagoneer
thanks for the advice and i'll let you know what i find.
Wngnutz is offline
