Ball joints on cherokee chief - JeepForum.com
post #1 of 18 Old 03-25-2013, 09:25 AM Thread Starter
jeepdj5
1982 FSJ Cherokee
I have a 82 Cherokee chief wide/track, I need passenger side ball joints BAD!! Is it pretty strait foreword (my dad has the press tool) any tricks to it? I have never done them, it's pretty rusty hopefully it pops apart! I'm going to do the upper and lower on the passenger side, the driver side is tight!! Any help will be nice!
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #2 of 18 Old 03-25-2013, 03:48 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
It would be a Dana 44, HELP!
jeepdj5 is offline
post #3 of 18 Old 03-25-2013, 03:58 PM
revelc
1985 FSJ Wagoneer
Have you tried hitting it on the side? Not on the ball joint directly but on the housing it sets in.
http://youtu.be/bf77O90BwKc^
five seconds of Googling
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #4 of 18 Old 03-25-2013, 04:16 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
That's not what I mean, what I mean is, is there Amy tricks to it, this is my first car/truck/JEEP, so I have never done them, I have watched once, is it pretty easy on these jeeps?
jeepdj5 is offline
post #5 of 18 Old 03-25-2013, 04:30 PM
revelc
1985 FSJ Wagoneer
A Dana 44 is a Dana 44 no matter what it's on.
I am a mechanic and some jobs seem even intimidating for me. But once I do them a few times they become much easier.
The person you really need to talk to and learn from is an old timer.
I learned more in the year that I worked with my great uncle restoring hot rods than I have at tech school, college classes, or on my own.
Their wealth of knowledge is invaluable.
Wisdom is worth more than silver, it brings more profit than gold.
If time is money the bible isn't too far off
revelc is offline
post #6 of 18 Old 03-25-2013, 04:54 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
Thanks!! I will get it done!! Some how..... If the wheels even come off lol!! There pretty rusty might have to hammer them off!!
jeepdj5 is offline
post #7 of 18 Old 03-25-2013, 05:08 PM
revelc
1985 FSJ Wagoneer
Using a hammer on the side of a ball joint. Not on it directly can sometimes simply make them fall out. Give it a shot.
revelc is offline
post #8 of 18 Old 03-25-2013, 07:38 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
Thanks revelc!!!! I will try that when I get it apart!! Hopefully the wheels come off, I have seen them get vary stuck before
jeepdj5 is offline
post #9 of 18 Old 03-25-2013, 07:56 PM
revelc
1985 FSJ Wagoneer
Be careful not to over torque the wheels. If they are hard to get off someone probably over tightened them or if its bad they could be cross threaded.
revelc is offline
post #10 of 18 Old 03-25-2013, 07:56 PM
CSP
The spindle can be tough to get off. I've found that there can be room to turn the knuckle to the steering stop and then use a punch from the backside of the knuckle, alternating between the top and bottom, to drive them out. Lots of people try to wedge a chisel between the spindle and knuckle, which usually damages the side of the spindle mounting face (just clean it up with a grinder or file if this happens). Soak the spindle/knuckle connection point well with penetrating fluid.
CSP is offline
post #11 of 18 Old 03-25-2013, 08:12 PM
RockRollin
1990 FSJ Wagoneer
That is a solid tip, works well on tie rods as well. Two hammers, both sides simultaneously. Good call
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #12 of 18 Old 03-25-2013, 08:21 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
I have not had them off since I have owned it lol! I always toque them to speck
jeepdj5 is offline
post #13 of 18 Old 03-25-2013, 08:24 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
Will do!!
jeepdj5 is offline
post #14 of 18 Old 03-27-2013, 09:49 PM Thread Starter
jeepdj5
1982 FSJ Cherokee
Wait how do u do this?
jeepdj5 is offline
post #15 of 18 Old 03-28-2013, 07:53 AM
CSP
Once you have the wheel/tire, brake calipers, and wheelbearing hub off turn the knuckle all the way so that the steering arm points away from the center of the vehicle. Look around at the backside of the knuckle and you can see the backside of the spindle. Drive the spindle off from the backside.
CSP is offline
