is it bad to get older j series?
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I feel like when i look for parts or mods for early 70s they just arnt really out there.
I was looking for a stable tow rig and something that could take on the trail if it had too. do J-series have decent clearance or are they pretty low? I have not actually seen that many in person. I think we have two in town and both have lifts. I'm looking at a j4000 right now but the aftermarket support seems really low.. and im not sure if its a mistake to pursue it because i dont know if it will have enough clearance.
They Call me..Peej 2003 TJ SE Trail Rider/DD 1982 CJ5 Project |
#2 |
Vendor
The early J-trucks were pretty low (compared to the later 76-88 ones) and the axles aren't the greatest. Some will have 2 piece axles in the rear, they will all (73 and earlier) will have drum brakes in the front with closed knuckle front axle.
You should stick with 76 and up because they are much easier to get parts for...
BJ's Off-Road http://www.bjsoffroad.com Specializing in Full-Size Jeeps -- 1984-1991 Grand Wagoneers, 1963-1988 J-trucks, 1974-1983 Cherokees and 1963-1983 Wagoneers! Check us out on Facebook! www.facebook.com/bjsoffroad |
#3 |
What are people doing about Q-Track fluid for the old quadra-tracks pre 80? They took a special Jeep only quadra track fluid if I remember correct.
#4 |
I'll have to make a note on that Q-track fluid - perhaps check with Borg-Warner next time I talk to them.
As far as the early J-series - WANT! I'm trying to find a pickup, and my top three choices are: 1974 or earlier J-series/Gladiator V8 (pref. AMC 260 or 401) MJ w/242ci 1974 or earlier Dodge W-series Diesel or V8 Why 1974 or earlier? So I don't have to deal with the California Air Police - I can tune it properly and run it cleaner than it did from the factory (and cleaner than most trucks twenty years newer...)
Kelley's Works in Progress - www.kelleyswip.com KWiP Parts Exchange - www.kelleyswip.com/exchange.html "recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm) "Outback AIDS - Alcohol-Induced Dizzy Spells" |
#5 | |
Vendor
Quadratrac Fluid, you can pay $12-15 at Jeep or buy this stuff from us, it is still expensive but not too horrible: http://www.bjsoffroad.com/cartgenie/prodInfo.asp?pid=76&cid=4 The other option is to put a part time kit in the Quadratrac and then it just takes regular ATF. Thanks.
#6 |
AND you can get a 17% O/D kit if yours is only a highway hauler! (BTW, the BW Quadratrac was only available with TH400 between '73 and '79. There was a New Process NP219 called Quadratrac in '81/82 but they aren't related except by name. Those were behind 727 trans)
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
