-   Full Size Jeep Forum (http://www.jeepforum.com/forum/f57/)
-   -   Axle swap, vacuum hubs to locking hubs (http://www.jeepforum.com/forum/f57/axle-swap-vacuum-hubs-locking-hubs-1507030/)
1997jeepZJ 04-09-2013 10:23 PM
okay so just recently i swapped a 1982 wagoneer dana44 with manual locking hubs on to my 83 wagoneer which had vacuum hubs and lines going to the diff cover. before i did this swap, i could put my jeep in 4wd and it would only turn the drive line, not the hubs, but now it wont spin the drive line, i dont have the drive line hooked up but it should still turn the yoke on the transfer case? i thought possible plugging the lines to the axle would fix this problem but it didnt. Now is there any way of fixing this issue? and has anyone done before? is there some sort of loop thats not being completed or something? :confused:
1997jeepZJ 04-09-2013 10:39 PM
revelc 04-09-2013 11:10 PM
1 Attachment(s)
Attachment 604800
Huh?
Is it a quadratrac?
If its a part time t-case it's not good to engage 4x4 with only the rear engaged.
But if it is in 4-low it should spin both the rear and front. Your chain might be broken.
RockRollin 04-10-2013 04:32 AM
Your saying hubs. Are you referring to the vacuum operated slip collar on the axle housing. Can you provide a pic of your old axle.
Onward. If you had the vacuum actuated axle, yes you need to remove and plug those lines.
Also check the lines going to the actuator on the t-case for leaks. Do you know which t-case you have?
paintballtruck 04-10-2013 08:28 AM
is one tire turning one way and the other turning opposite if it is you are fine the spiders are turning not the ring and pinion
CSP 04-10-2013 08:42 AM
First thing you could have done was just swap the manual hubs to the old axle. The only thing that was vacuum on it was a disconnect in the third member. The hubs were full time (not vacuum activated).
Lock the hubs in and turn the yoke by hand. One or both of the tires should turn. If only one turns that's normal for an open differential. The old vacuum setup has nothing to do with the new axle engaging. If the lockouts are locked, it's effectively in 4WD once you have the front driveshaft re-installed.
CSP 04-10-2013 08:45 AM
That's exactly what the OP had. He swapped that axle out for a non-vac disconnect axle and is expecting to be able to lock the hubs, turn the tire/wheel and see the input yoke turning. It won't though because of the spiders in the open diff. He needs to turn the input yoke by hand and see that one or both of the wheels/tires are turning.
http://www.jeepforum.com/forum/f57/a...-hubs-1507030/
revelc 04-10-2013 08:49 AM
Oh gosh. I thought he meant he engaged the transfer case and the front drive shaft wasn't turning. If he's spinning the hub on an open diff that makes sense.
RockRollin 04-10-2013 09:40 AM
Got it. That vacuum hub thing threw me
muddy93 04-10-2013 01:46 PM
If it's a "select-track", (see diagram at bottom) you can NOT just plug the lines that origionally went to the front axle. The select track system sent vacuum to the front axle, and once the front axle engaged, vacuum was then sent to the T-case to engage it. So, if you simply cap the front axle lines, vacuum will never get to the T-case to engage it.
here's a vac diagram for the select track system.
http://www.n0kfb.org/homepage/amc/te...ematic_4wd.gif
1997jeepZJ 04-13-2013 05:38 PM
this is a 229 trasnfercase, what do i need to do? loop the lines?
muddy93 04-15-2013 06:01 AM
Yep, prety much.
you basically need to duplicate the vac setup on the later 229 rigs. you can either "loop the lines", or you can remove the old lines that go to the front axle, and re-route the T-case lines so they come directly to the switch.
One rather important thing worth noting; with the 229 case, you MUST engage the hubs BEFORE you put the case in 4wd. Putting the case in 4wd with the hubs unlocked will cause the VC to burn up.
1997jeepZJ 04-15-2013 05:52 PM
So as you said, later 229 jeeps, later is 84 and up? and whats the difference between the 229 off and 83 and later ones
muddy93 04-16-2013 06:46 AM
short version: The T-case is the same. It's the axles and vacuum system that changed.
Long version:
As far as I know, all of the 229's were the same. What changed was the front axle, and it was because of the front axle that the vacuum systems were different between the years.
Here's a quote from the "axle identification" thread (top of the FSJ section)
"**1982-1984 (6-lug only) could have a vacuum disconnect front axle - I have seen some 1985's with this as well."
With the disconnect axle, the axle needs to be engaged first (in order to get the front drive shaft spinning so the case doesn't grind). To do this, they tied the two vacuum actuators together in such a way that the T-case would not get vacuum untill AFTER the front axle was engaged.
On the later 229 rigs the drive shaft was alwayse spinning because they did not use a disconnect axle. Because of that, the dash switch could be hooked directly to the vacuum actuator on the T-case.
Also, because the 229, when in 4 hi, is a full time/AWD case, it has a viscus coupling that connects the front and rear outputs. If you try to drive in 4hi with the front end disconnected (i.e. not locking your new manual hubs), the viscus coupling will overheat and self destruct.
The time now is 03:19 AM.
