Axle play - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Axle play
Year End Clearance Sale! Save 20%NEW!! HMF 50"-52" light bar mounting brackets!! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-07-2014, 06:14 PM   #1
SemperFiGuy
Axle play
89 GW, far as I know it's stock, 112,000.
Just picked the Jeep up, pulled tire to repair leak, decided to pull the drum off since I'm there, axle shaft has a small amount of in/out play in it, any thoughts? Thanks.
SemperFiGuy is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 06:05 PM   #2
Partsmke
1987 YJ Wrangler
The axle wheel bearing seal is what adjusts bearing tension, it is a crush sleeve, You have to replace the wheel bearings to replace the seal in most cases. Set 10 bearing with a National Seal # NS9912.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 10:00 PM   #3
SemperFiGuy
So no play? Thanks for the PN's.
Unread 12-11-2014, 08:41 PM   #4
0125JeepGuy
if its small then dont be too concerned. note that there should not be any though. my old axle was a mess it had about 1/4 - 3/8 inch of play on both sides and i just swapped the whole thing.
0125JeepGuy is offline   Reply With Quote Quick reply to this message
