axel shaft u joint problem - JeepForum.com
post #1 of 4 Old 03-24-2013, 09:18 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So I am doing my axel shaft u joint and I got it all out and was putting it back together and one of my bearing cup's will not seat to the point where I can get the snap ring on. The old u joint bearing cap was also not seated and had no snap ring in place. Does this mean there is a problem with my axel shaft and I need a new one to do this job right.
cookingguy is offline
post #2 of 4 Old 03-25-2013, 09:12 AM
timgr
1975 CJ6
Usually it means you have one of the needles lying in the bottom of the cup.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 4 Old 03-25-2013, 08:58 PM
CSP
x2 on the needle falling off of the side of the cup as it was installed.
CSP is offline
post #4 of 4 Old 03-25-2013, 10:08 PM Thread Starter
cookingguy
1979 FSJ Cherokee
Not the needle checked all good. Talked to my drivline shop today and my guy there said that sometimes the ears can get a little tweeked to fix it just open it up just a little bit with a punch. will be trying that on wed when I can get back to working on the jeep
