Any info - JeepForum.com
post #1 of 7 Old 01-25-2013, 08:08 PM Thread Starter
DDowns
1956 J-Series Truck
Any info
Hello! thanks for any and all information. I picked up a willys truck 1956 ruff very ruff, but NO rust. It came with a 1969 350 with a set of camel hump heads. Backed with a 350 turbo glide trans and a gear driven transfer case. not bad for $750.00
My questions are simple 1) using existing stock axles, has any one ever put disk breaks onto the front / and or the rear with out buying one of those over priced kits? If so what would the parts be from what make and year vehicle?
2)Has anyone ever put power steering, or a rack - pinion set up on this type of truck system were the existing gear box go's through the frame?
One way or another I will figure it out lol just trying to shorten the R/D part with known information. Thanks for any and all info. jeep it safe. Sorry for all the type-o's I have a broken right hand at the moment.
DDowns is offline
post #2 of 7 Old 01-26-2013, 12:21 PM
Dngrs1
1979 CJ7
All I can offer is I wouldn't call a '56 Willys pickup a "J-series truck". The J-series wasn't made until '62 with the Gladiator.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #3 of 7 Old 01-28-2013, 11:54 PM Thread Starter
DDowns
1956 J-Series Truck
well in the pull down menu when I filled out my information, there was no selection for *just* truck
DDowns is offline
post #4 of 7 Old 01-29-2013, 12:01 AM Thread Starter
DDowns
1956 J-Series Truck
Also I just checked and FC-150 is also not an option. It is, what it is.
DDowns is offline
post #5 of 7 Old 01-31-2013, 01:33 PM
strvger01
1966 CJ5
i've seen a number of conversions for sale on 4x4 aftermarket sites and ebay, craig's list, here in the 'for sale' forum, etc., depending on what stock axles you have. actually, a cheaper and easier option might be to just swap your axles with more modern ones. jy axles aren't too expensive. just measure your axle length, spring pad mounting lengths, brake drum-brake drum lengths, etc., and find the axles that will come close. you will undoubtedly be getting stronger axles and much better brakes as well. you can always hang onto the original axles if you ever decide to sell it to a collector if you want.
just a thought.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #6 of 7 Old 02-02-2013, 01:33 AM Thread Starter
DDowns
1956 J-Series Truck
thanks
thanks for your time to in-put, and your thoughts. I was thinking the same thing, and will probable go in that direction.
DDowns is offline
post #7 of 7 Old 02-04-2013, 01:34 PM
timgr
1975 CJ6
Conventional Jeep trucks and wagons from that era are "Utility Trucks" and "Utility Wagons." There were also forward control trucks, "FCs."
Yep, Jeepforum does not cover them. Is it a Utility or a FC?
I guess the site with the most traffic re these trucks would be Willystech http://mvpimages.net/willys/show.htm - but they have a mailing list format, not a forum like here.
Can't help you with the PS conversion, without knowing whether it's a FC or a Utility.
The brake question is easy if you want to keep your existing axles. Disk conversion is the same for all the Jeep closed-knuckle front axles. You can do this using junk yard parts. Check out the JP article http://mvpimages.net/willys/show.htm - there are lots of other resources on the internet if you search. If you have questions, I suggest you ask where there are lots of owners of old Jeeps with closed-knuckle front axles, like Willystech or earlyCJ5.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
