another gear oil type question... - JeepForum.com
post #1 of 6 Old 05-08-2013, 03:31 PM Thread Starter
JUNK726
Guest
1974 J-Series Truck
ok..so before anyone flames me for asking..i HAVE googled/searched this til my eyes bled.. i just wanna be sure and ask the pros...it's the LAST fluid change left for me under the ol J10...1974 with dana 44's...i found the tags on both diffs..so i know my gearing/etc..just was not sure on the REAR...mainly IF or how to tell if i have anything "weird" or sumthin..trac loc/towing rear etc...tags say 3.54..so i assume stock..but do u guys run any LSD additives in these? or just plain ol gear oil and shut my face?! thanks again guys!! hit me...(gotta say..i am pretty proud that my tranny and quadratrac show NO leaks..yet! and oil pan...just a SMALL drip...the "before" was the puddle style in driveway..but NO more!!
JUNK726 is offline
post #2 of 6 Old 05-08-2013, 06:19 PM
cookingguy
1979 FSJ Cherokee
If you Google the id number on the tag it should tell you if you are open diff or not somtime there is another tag on the diff that will tell you bit they can be lost fall off etc on the old rigs like ours
cookingguy is offline
post #3 of 6 Old 05-08-2013, 06:36 PM
RockRollin
1990 FSJ Wagoneer
Well you have to pull the cover to change the fluid. See what ya have then. If you do need lsd additive, it won't hurt it to run to the parts store with just gear lube, or get it and return if not needed, or jack it up and turn one tire and see which way the opposing tire turns
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 6 Old 05-08-2013, 09:18 PM
pleontks
1976 J-Series Truck
do that.
Jack up rear so both tires are off the ground. Spin one tire forward. If the other one spins forward, you have a l/s and need the additive. If the other tire spins backwards, you're open, and just fluid is fine
Beauty is in the eye of the jeepowner.
pleontks is offline
post #5 of 6 Old 05-08-2013, 10:01 PM Thread Starter
JUNK726
Guest
1974 J-Series Truck
awesome! thanks guys! jacked up rear end..spun the tire and other tire went opposite way! so looks like im goin regular gear oil!
JUNK726 is offline
post #6 of 6 Old 05-09-2013, 12:05 AM
5-90
5-90's Avatar
1988 XJ Cherokee
You can run the BoM number on the axle (stamped on the right tube, and found on the tag) through the Dana Expert site and get the original configuration. Go to www.dana.com, and follow the prompts.
While you've got the cover off, examine the are behind the side gears (on the inner ends of the halfshafts,) and any clutch packs or whatever should be fairly obvious - visually - because it won't be a cast surface behind the gear.
However, if you're not sure, you can go ahead and add LSD FM to the oil - if it's not needed, it won't cause you any trouble (I'd mix it in with all my stock - I had two rigs with OEM LSD rear, and three without. Same gear oil in all axles.) Use GL-5 spec oil in the axles - if you have a manual, you're probably going to want GL-3 so you don't dissolve the synchroniser rings (unless you get a "performance synthetic" GL-5 that specifically sez it's "Safe for use with Yellow Metal." If you get performance synthetic gear oil, yellow metal safe, with LSD FM premixed? Go ahead and use it in everything, she'll be right, mate! (LSD FM won't cause any trouble in the transmission - it's the added sulphur-based EP lubes in the mineral-based GL-5 oils that's a problem.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
