alingnment question - Page 2 - JeepForum.com
post #16 of 22 Old 03-08-2013, 07:04 AM
OrangeCJ-5
1978 CJ5
It could be a problem. I've never done one on a FSJ. You would need to remove the U-bolts to gain access to the bolt/pin. Does the axle look like it is sitting on the perch in a different position than the other side? Any pictures?
OrangeCJ-5 is offline
post #17 of 22 Old 03-08-2013, 08:25 AM Thread Starter
cookingguy
1979 FSJ Cherokee
i will try to get some pics up today
cookingguy is offline
post #18 of 22 Old 03-09-2013, 04:02 PM Thread Starter
cookingguy
1979 FSJ Cherokee
here are a couple of pics of the side I think is the problem.
post #19 of 22 Old 03-09-2013, 04:45 PM
RockRollin
1990 FSJ Wagoneer
Those blocks are a problem
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #20 of 22 Old 03-09-2013, 05:05 PM Thread Starter
cookingguy
1979 FSJ Cherokee
why would lift blocks be a problem? I do want to get rid of them and go with a 4inch spring lift for the rear I don't think I need to do new springs for the front since they should already be 4 inch springs. But the new rear springs are gonna have to wait till I have the $500 dollars
post #21 of 22 Old 03-09-2013, 05:17 PM
CSP
That bent pin could be just bent from the point where the ubolt plate is. I doubt that has anything to do with it.
You say you have an alignment print out. Are the readings within factory spec? The sheet should give both. If it's in spec stop looking for a problem that isn't there.
CSP is offline
post #22 of 22 Old 03-09-2013, 05:33 PM Thread Starter
cookingguy
1979 FSJ Cherokee
i don't have a print out that was somebody else I am going to be getting another alingment done this week and post up the results. I do know there is a problem because of the doglegging and I am pretty darn sure the frame is not bent.
