alingnment question - JeepForum.com
post #1 of 22 Old 03-01-2013, 06:24 PM Thread Starter
cookingguy
1979 FSJ Cherokee
alingnment question
I need to get an alingnment done on my 79way cherokee. This is the second one in less than 3 months. The quy at the shop i took it to said there is only one adjustment to be made. Then the other day my buddy was behind me and told me it looked like i was driving sideways. Is the guy atthe shop i took it to full of it or just doesn't know what he is talking about. How many adjustments should be getting made?
cookingguy is offline
post #2 of 22 Old 03-01-2013, 07:22 PM
pleontks
1976 J-Series Truck
sounds like a bent frame
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 22 Old 03-01-2013, 07:33 PM
Saul32
1988 FSJ Wagoneer
^yep
Nothing important...
Saul32 is offline
post #4 of 22 Old 03-01-2013, 09:10 PM
CSP
There is only one thing that's really adjustable with a solid front axle and that's toe (tow is what you do when you pull something behind your vehicle). Camber and caster are not an adjustable measurement without special parts and the adjustment you can do is pretty limited. Any shop, regardless of what they can or can't adjust, can give you a printout of what the measurements of camber, caster, and toe are along with what they are supposed to be. At least then you would know if something is out of whack.
No self-respecting shop is going to adjust caster with shims between the springs and perches. Shims are hack and are a liablility to a shop should they break. They will use an adjustable spanner on the top balljoint, but you can only get a couple of degrees of alignment out of them at most.
Keep in mind that the front axle on a fullsize Jeep is wider than the rear axle, so looking down one side it can look like it's doglegging.
CSP is offline
post #5 of 22 Old 03-01-2013, 09:42 PM Thread Starter
cookingguy
1979 FSJ Cherokee
I dont think its a bent frame because after the first alingment my girlfriend was following me and she said it looked fine and i trust her shi us a CM in the seabees.
post #6 of 22 Old 03-02-2013, 06:06 AM
Dave145
1976 FSJ Cherokee
My truck looks like its sideways sometimes too. I've been told that this is because of the offset used on these trucks with the way they moved the rear axle to the side
Dave145 is offline
post #7 of 22 Old 03-02-2013, 07:44 AM
CSP
You don't adjust pinion to correct caster. Yes, I know that one affects the other, but caster always takes priority and there isn't a specification for pinion angle. There is one for caster. I know this may sound nitpicky, but I don't want someone to think that they can move their pinion to an angle they think is correct and assume that caster will be correct too based on your statement that if you adjust pinion, caster should be correct.
CSP is offline
post #8 of 22 Old 03-02-2013, 09:58 AM
pleontks
1976 J-Series Truck
Aand if the castor is off, the only difference it would make to the driving experience would be lack of self-centering?
Just trying to fill in some knowledge gaps...
pleontks is offline
post #9 of 22 Old 03-03-2013, 07:29 AM
timgr
1975 CJ6
Caster affects stability as well as return to center. You need some caster or the steering becomes too responsive, to the point of being uncontrollable.
Think of the Easy Rider bikes - long forks make huge positive caster, very stable with easy hands-off riding.
And FYI it's "caster," like the casters on a TV cart - Google "castor" and you'll find lots of articles about the stars and beavers ...
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #10 of 22 Old 03-03-2013, 09:32 AM
OrangeCJ-5
1978 CJ5
Another possibility could be the centering pin on a rear leaf spring pack is broken causing the axle to not be positioned correctly on the spring. Because of this the thrust angle would be off. Just throwing that out there
OrangeCJ-5 is offline
post #11 of 22 Old 03-03-2013, 11:18 AM
Eric1080
1978 J-Series Truck
i have a printoff of my alignment from a good shop. i cant post a picture of the numbers if u want
Eric1080 is offline
post #12 of 22 Old 03-04-2013, 09:58 AM
pleontks
1976 J-Series Truck
Thanks, timgr. I like your example. I can't even remember last TV cart I saw.
pleontks is offline
post #13 of 22 Old 03-07-2013, 06:47 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So I was checking out my rear leafs today and the long bolt coming out of the center of the passanger side leaf is pretty bent could that be the cause of my problems? How hard is it to replace?
post #14 of 22 Old 03-07-2013, 08:56 PM
super98lsc
I know my 90 has a front and rear track bar to center the axles, if yours does perhaps its bushings are shot allowing the axles to walk.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #15 of 22 Old 03-07-2013, 09:36 PM Thread Starter
cookingguy
1979 FSJ Cherokee
pretty sure the 1979 does not have a track bar
