Agnes is giving me Problems.. - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Agnes is giving me Problems..
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 03-13-2014, 03:46 PM   #1
Saul32
1988 FSJ Wagoneer
So back in October I switched out a faulty Holley Truck Avenger for a new one, at Jegs cost, and removed the egr stuff and replaced my exhaust manifolds. She ran great then I put her away for the winter. I started her up on Sunday w no struggle at all. I only let her run for like 2 minutes. Then I went back about 30 min later and it struggled and wouldn't turn over. The battery is new and so is the starter and alternator. The starter seemed to make the clicking sound and then nothing. I checked the battery connections but that's about it. It was too cold to wrench. All the gauges and lights seem fine though.... Should I recalibrate the carb? October weather was about 50's. Winter has been up to negative 42 here and about high teens lately. .
Any help? I'm going to try n get to it this weekend.
Nothing important...
Saul32 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2014, 03:52 PM   #2
super98lsc
If it wont turn then its not Fuel/Spark related. A no crank (Meaning engine wont spin) will be the battery/starter/or a seized up engine. First thing is disconnect the batter then rotate the crank shaft from the harmonic balancer bolt using a large ratchet. Make certain the engine turns 360 degrees by hand. Likely the battery is simply low on charge, it can have enough current (Amps) to light up lights etc but not nearly enough to turn over the engine especially when its cold/tight. If the engine spins by hand then charge the battery and re-try cranking it over. If the starter still does nothing then it could be a bad starter motor. The brushes wear down and it can get hung in a "dead spot" on the commutator where the power does not flow to the armature and thus the motor does nothing. You will only hear the clicking of the solenoid trying to engage the bendix drive but it will not spin the engine. If thats the case pull the starter and have it bench tested or just replace it.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline   Reply With Quote Quick reply to this message
Unread 03-18-2014, 05:38 PM   #3
carnuck
1984 J-Series Truck
make sure all the cables are tight.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 11:11 PM   #4
Saul32
1988 FSJ Wagoneer
Gave her a jump start and let her run for 20min 3 days ago. Went back today and she started right up. Ran her another 30min.
And about 2 hrs ago I sold my 2012 Chevy Equinox so Agnes will be my daily driver again!!
Beer me
Unread 03-24-2014, 05:20 AM   #5
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Beer me
I have a weak alternator. Upon first start it barley shows charge. After a few minutes of running and a little revving, it charges at 14.2 . Just something to look at.
as Super suggested, check and clean battery connections, both +\-, both ends of cables
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
RockRollin is offline   Reply With Quote Quick reply to this message
