aftermarket tach install ??? - JeepForum.com
post #1 of 6 Old 02-10-2011, 05:05 PM Thread Starter
Eric1080
1978 J-Series Truck
im thinking of getting this: http://www.summitracing.com/parts/ATM-2301/
question is- how does it install? thanks for the help
Eric1080 is offline
post #2 of 6 Old 02-10-2011, 05:30 PM
JeepOrvis97
JeepOrvis97's Avatar
Probably simply connects to one if the sides of the coil. I can't remember which one exactly.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #3 of 6 Old 02-10-2011, 08:22 PM
WagoneerCraig
1989 FSJ Wagoneer
^^ Yup Attaches to the coil . Instructions should inform you on that part . And if there is a power lead for the night light ? It generally plugs into to your lights fuse or ignition
WagoneerCraig is offline
post #4 of 6 Old 02-10-2011, 11:32 PM
gcarson64
1988 FSJ Wagoneer
i installed an aftermarket tach on my wagon, and just looked at the instructions. i had no problem at all installing mine. i dont see why you would.
gcarson64 is offline
post #5 of 6 Old 02-11-2011, 09:07 AM
CSP
Aftermarket tachs are a simple four wire hookup. I've never seen one stray from this wiring scheme. Green to the negative side of the coil, red for key on power, white for lighting, and black for the ground.
CSP is offline
post #6 of 6 Old 02-11-2011, 09:26 AM Thread Starter
Eric1080
1978 J-Series Truck
excellent. thanks for the help guys. now to drop hints to my wife
Eric1080 is offline
Cannot re-install drive hub marilynmacabre Full Size Jeep Forum 2 08-26-2009 11:24 PM
adding ac (aftermarket units) Scott00TJ Full Size Jeep Forum 1 08-06-2009 01:50 PM
J20: T18 and D20 from a 6 cyl install in a CJ7 OlivergreenCJ7 Full Size Jeep Forum 0 11-18-2008 07:53 PM
aftermarket hood pad for 83 wag? bturnerexpress Full Size Jeep Forum 5 05-22-2008 09:45 PM
7" or 8" wide aftermarket wheels on Grand Waggy? Hubjeep Full Size Jeep Forum 4 12-06-2006 03:45 PM
