Absolute minimum lift for 35s n/t waggy - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Absolute minimum lift for 35s n/t waggy
Win a $250 Gift Card to ZoneOffroad.com - 4th of July FaceRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-27-2015, 10:29 AM   #1
alienature
2010 JK Wrangler
Hello. Im new to the fsj world, I just got an 87 gw and I'm getting ready to lift it up. I have a set of 35 12.5 15 km2s off of a wrangler I sold that will be going under the wagon. From what I've read Rustys 6" and some trimming will clear 35s. My question is can I get away with a shorter lift and maybe a little more ? I Rolled the 35s next to the stock tires and a 6" lift seems excessive. But I yield to experience. Thanks!
alienature is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 04:19 PM   #2
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
I can tell you i am running 33's and a 4" lift wasn't enough without some minor trimming up under the rear wheel wells and at the front corners of the fenders. I think 6" is the minimum on an NT if you wish to run 33's without trimming so 35'a will be even more difficult.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 07:02 AM   #3
alienature
2010 JK Wrangler
I Don't have a problem with trimming, Florida doesn't have any laws regarding fenders, And my body isn't in the best shape. So significant cutting is fine
Unread 06-29-2015, 10:22 AM   #4
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Keep in mind there isnt much trimming you can do in the back without cutting into the interior of the body
-Andrew
