91 GW with clanking noise while in gear - JeepForum.com
post #1 of 5 Old 03-17-2013, 03:54 AM Thread Starter
Macpsk
1991 FSJ Wagoneer
my '91 grand wagoneer often has a clanking noise under the hood whenever i first start her up and put her in gear (happens in Drive or Reverse). it doesn't happen in Neutral. also, the clanking noise speeds up when i accelerate and slows down when i decelerate. while in gear at idle, the clanking noise seems to repeat about once a second.
unfortunately, i can't get under the truck to check for the noise while i'm in gear.
anyone got any ideas of what could be causing this clanking noise? any ideas on how i can try to pinpoint where the noise is coming from?
Macpsk is offline
post #2 of 5 Old 03-17-2013, 07:53 AM
RockRollin
1990 FSJ Wagoneer
How is the oil pressure? Its hard to diagnose "clanking" has the starter been replaced lately, checked the flywheel, and torque converter bolts? Exhaust leak?
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 5 Old 03-17-2013, 08:29 AM
WOLFMAN75
1989 FSJ Wagoneer
Sounds funny, but make sure hub caps are secure. I was getting rattle from those, will rattle whether its in gear or not.
WOLFMAN75 is offline
post #4 of 5 Old 03-17-2013, 09:57 AM
revelc
1985 FSJ Wagoneer
Check your drive shaft u-joints.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #5 of 5 Old 03-17-2013, 12:48 PM
super98lsc
if you blip the throttle in park or neutral does it sound ok? X2 on checking converter bolts, and motor mounts. Get someone to pop in gear that you trust w your life and listen under it. Could be something in the trans or converter assuming the engine and faceplate are good. A rod bearing will hammer under load but also if you rev it by blipping the throttle.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
banging , grand wagoneer , in gear , noise , rattling
