90 Grand Wagoneer Question - JeepForum.com
post #1 of 4 Old 06-06-2012, 07:57 PM Thread Starter
CoachKip
I am considering purchasing a 90 Jeep Wagoneer. It is in great shape, of course needs some work and it will be nice to have a manageable project.
My question is this. It hesitates to the point of nearly stalling during acceleration from about 10-25 mph. I don't know anything about carburetors and not much more about engines. Is this worth taking on as a total nubie? Is this going to be a fairly inexpensive fix to get working correctly?
CoachKip is offline
post #2 of 4 Old 06-07-2012, 07:36 AM
muddy93
1987 FSJ Wagoneer
Well, the process of rebuilding the carburetor is really simple. you just have to take your time and make sure all the new parts go back in, the same way that the old ones came out. And, you should be able to pick up a decent rebuild kit for around $30 or less. However, the time consuming part is getting everything tuned just right once you get the carb back together.
take a look at this thread, http://www.ifsja.org/forums/vb/showthread.php?t=101921 it's prety much a step-by-step for rebuilding a 2150 (that's the carb that should be on a 90 GW).
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 4 Old 06-07-2012, 07:54 AM
CSP
It could be a number of things, so don't just jump on the assumption that it's the carb. It could be something as simple as a vacuum line with a crack in it.
Not to say that it isn't the carb or that a rebuild is a bad idea, but there are a number of possibilities.
CSP is offline
post #4 of 4 Old 06-09-2012, 04:26 PM
RockRollin
1990 FSJ Wagoneer
Its worth it if you want a GW. You probably won't find one in perfect condition without spending double digit thousands. Common problems are ignition, vacume, carburation, and pretty much everything else. There are alot of resources online without alot of experience necessary. If its worth the work to you then go for it.
RockRollin is offline
carburetor , engine , stall , wagoneer
68 Grand wagoneer Question Rokjeep Full Size Jeep Forum 9 03-07-2010 09:46 PM
Shock absorber question for 89 Grand Wagoneer TurboM3 Full Size Jeep Forum 5 08-06-2009 12:42 PM
Color Question - 1990 Grand Wagoneer thejudge Full Size Jeep Forum 1 01-17-2009 12:34 AM
89 Grand wagoneer engine swap question gimme_fuel Full Size Jeep Forum 13 01-10-2009 12:57 AM
89 grand wagoneer question redxtc Full Size Jeep Forum 2 12-14-2007 07:02 AM
