89 Grand Tankoneer Engine Stuff - JeepForum.com
post #1 of 3 Old 02-05-2011, 09:14 PM Thread Starter
DrHicks
1994 ZJ
Obviously the beast has the AMC 360 in it. Everything is stock.
I've done tons of mechanical stuff for many years, but I'm not familiar with this drive-train. So I've got some questions here.
1. I've got a slight shudder at idle. Not bad, and it sure seems to smooth out nicely at speed, but it is noticeable. I've got new plugs & wires, but is there something else likely? Or is that just typical of this engine?
2. Is there any good reason to install a performance coil? There is nothing wrong with the stock coil, so I don't need to replace it. On this particular engine, is it worth it?
3. This vehicle came from Co Springs, and supposedly has some sort of "high altitude adjustment" on it. What is that supposed to be? I don't see anything unusual on the engine, so is it something internal in the carb?
Any other thoughts or suggestions?
Thanks guys!
DrHicks is offline
post #2 of 3 Old 02-06-2011, 06:32 AM
BioTex
1979 CJ7
I think the altitude adjustment is as simple as telling the computer you are at altitude by grounding or ungrounding a particular wire. That's the way it is on my CJ, so perhaps the same.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 3 Old 02-06-2011, 10:24 AM
Eric1080
1978 J-Series Truck
the carb could (and should) be adjusted for high altitude if it came from co springs. which could be different rods and jets and springs. which could explain your hesitation and stumble just off idle. mine was set up for 8k feet and i had it brought to ny (1500 feet). had a bad stumble and erratic idle. i had to adjust the carb and the idle mixture screws and gtg. many people choose to upgrade to a hotter ignition (dui, msd, teamrush, etc) personally i cant leave stock alone, i have to upgrade
Eric1080 is offline
89 Grand wagoneer engine swap question gimme_fuel Full Size Jeep Forum 13 01-10-2009 12:57 AM
Newer engine for 86 Grand Wagoneer 4x4joe Full Size Jeep Forum 2 10-03-2007 10:30 AM
89 grand wagoneer engine/trans rebuild??? blacksparrow Full Size Jeep Forum 1 05-17-2007 10:14 AM
Grand wagoneer grand cherokee engine- KWAG Full Size Jeep Forum 0 04-29-2005 07:55 AM
New Engine for 89 Grand Wagoneer wounded woody Full Size Jeep Forum 2 11-12-2004 09:51 PM
