88 Wagoneer Starting Problems - JeepForum.com
post #1 of 4 Old 12-09-2001, 09:05 AM Thread Starter
Robert Bouy
Hello,
I have an 88 Wagoneer, 162K miles in great shape, it runs great, it does 4wd great, and it rides great, that is when I can get it started.
The problem is intermittent (getting more frequent though). Sometimes when I start I don't get any fire to the distributor cap (tested with a screwdriver near the frame). So I changed the ignition coil with a new and it started fine for a week, but now we are back to the same old thing. Also, sometimes if I let it sit for a couple of hours after a failed attempt at starting it will start right up with no problem.
From here the only things I know to check/change are the ignition module and the starter switch itself, but I don't know how to actually test those items and they are not covered in my manual (sorry still a budding enthusiast).
So if anyone has any suggestions on troubleshooting the above items, or on any other likely sources of the problem I sould appreciate it.
Robert Bouy is offline
post #2 of 4 Old 12-09-2001, 09:46 AM Thread Starter
Robert Bouy
By the way, It is an inline 6cyl.
Also some troubleshooting I've done already (though I am not sure how to interpret the results)
Coming into the ignition control module are two plugs (2 port and a 3 port plug).
the 2 port(connector) plug has only a yellow(y1) wire coming into it and plugs into the center of the ignition control module.
the 3 port plug has 3 wires (yellow(y2), green w/stripe, and black) and plugs into the right side (when viewed from above with the high voltage output pointing away from you).
Anyway, I checked the voltages across these wires with the ignition switch turned on and this is what i found.
y1 - green = 2.5volts (yellow wire on 2port connector)
y1 - black = 3.5volts
y1 - battery(negative) = 3.5volts
y2 - green = 8.0volts (yellow wire on 3port connector)
y2 - black = 11.0volts
y2 - battery(negative) = 11.0volts
post #3 of 4 Old 12-11-2001, 12:59 AM
Eduardo Villegas
Hi dear friend...I have had a 6 cil. wagoneer and it happened the same trouble. In my case, the trouble was a cable with connects the engine to the chassis, a grownd fat and black wire that is placed near the right piece of rubber that supports the engine.
I hope that this can help...
older jeeps forever
Eduardo Villegas is offline
post #4 of 4 Old 12-11-2001, 01:02 AM
Eduardo Villegas
older jeeps forever
Cold starting wagoneer jpwagoneer1979 Full Size Jeep Forum 8 12-08-2008 09:03 PM
90 grand wagoneer few problems Custom RooR Full Size Jeep Forum 3 03-12-2007 12:31 AM
'91 Grand Wagoneer: Starting issues. redrocket328 Full Size Jeep Forum 0 08-06-2006 06:47 PM
89 Wagoneer trans problems duke222 Full Size Jeep Forum 2 08-08-2005 09:03 PM
starting problems with 88 wagoneer silverscorpio Full Size Jeep Forum 1 08-17-2004 07:36 PM
