88 Waggy stock 360 rebuild - JeepForum.com
post #1 of 3 Old 03-29-2013, 08:26 AM Thread Starter
papa2big
1988 FSJ Wagoneer
I am going to be rebuilding my stock 360 this summer. Can anyone suggest a good kit or should I try and piece one together?
papa2big is offline
post #2 of 3 Old 03-29-2013, 09:48 AM
timgr
1975 CJ6
How much of a rebuild? Are you going to have the cylinders bored and fit new pistons? I suggest you talk to your machine shop about where to source the parts. They may be able to get the parts you need at competitive prices, and they will need the pistons when they bore the block. You should also hold off buying any parts until the block has been cleaned, inspected and measured. The condition of the bores will determine which pistons you need.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 3 Old 04-01-2013, 09:39 PM
revelc
1985 FSJ Wagoneer
Originally Posted by timgr
how much of a rebuild? Are you going to have the cylinders bored and fit new pistons? I suggest you talk to your machine shop about where to source the parts. They may be able to get the parts you need at competitive prices, and they will need the pistons when they bore the block. You should also hold off buying any parts until the block has been cleaned, inspected and measured. The condition of the bores will determine which pistons you need.
x2
You can get basic stuff like performance parts and gasket sets. Cam, timing set, seals, etc.
And you can get prices for pistons to formulate a budget.
But wait until you have the block inspected before you get pistons and bearings.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
