I have a problem with the tailgate window on my Grand Wagoneer.
I was able to remove the glass and identify the problem but I'm not sure how or what I need to fix it.
The bar/tray which the glass sits in, that is connected on the end of the 2 scissors, which makes the window go up and down, won't stay connected to the bolt or pin on the end of the scissor arms.
Can some one tell me if that is a bolt a on the end of the arm or some kind of pin or is it a rivet that has to be cut off and replaced with another rivet or bolt? What do I have to do to secure the bar/tray to the scissor assembly?
When I took the tailgate apart I didn't find any nuts or broken pins rattling around in the bottom of the gate... and I didn’t remove any bolts or nuts except for the entry panel.
Thanks for your time,
"g"
"g"
